Heater questions......????
Old Sep 23, 2004 | 05:37 AM
Sliced Beard's Avatar
Default Heater questions......????
I just recently installed a new heater core in my car and decided to try it out.
I put an OEM full length dual core radiator in my car when I first put it together and I have yet to use teh heater because the heater core I had leaked. Well this morning I let my car warm up and hop in and turn the heater on it blows nice and hot for the first mile or so. Well here is my problem......I thing my radiator is too big to support a heater because after I get going my radiator cools my car soo muych when it is cool outside (it was like 40-50's outside this morning, I dunno for sure) that my water does not get warm enough to heat the air
have any of you had a similar problem and what did you do about it?
Old Sep 23, 2004 | 06:46 AM
Default Re: Heater questions......???? (DirtySol)
wow, the tech forum has really slowed down as of late
Old Sep 23, 2004 | 08:42 AM
JimBlake's Avatar
Maybe your T-stat sticking open?? In order for the radiator to overcool the system, there has to be coolant flowing thru it...
Old Sep 23, 2004 | 08:45 AM
Default Re: Heater questions......???? (JimBlake)
hmmmm, I don't think that would be the problem because I never had this problem until I hooked my heater up yesterday.
T-stats are cheap so I will try that today after class and see what happens......hopefully it fixes the problem
Old Sep 23, 2004 | 09:00 AM
JimBlake's Avatar
Are you sure the cooling system isn't getting hot? (temperature gauge) Maybe it's simply air in the heater core? Or what about the cable/linkage that controls the heater valve?
Old Sep 23, 2004 | 09:10 AM
guage stays buried on the cold side, cables are hooked up correctly, they are brand new and teh air in teh heater core would have nothing to do with the air that is comng out.........when I am sitting still the air is nice and warm and teh cars temp stays nice and firm.....the problem only comes when I am moving and there is moving air around to cool the engine and water
Old Sep 23, 2004 | 09:34 AM
Sack Master's Avatar
Thermostat..
Old Nov 6, 2004 | 10:51 PM
Default Re: Heater questions......???? (Sack Master)
unded up being a bent thermostat
I was at the Danbury, CT meet about a month ago changing the t-stat and discovered that it was bent.....was really wierd
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
eg_21
11
Jan 4, 2010 09:03 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
oMek
Feb 4, 2004 06:55 PM
FOC-US2K
21
May 6, 2003 11:02 PM
