heater core question..pic..
Old Sep 25, 2011 | 03:25 PM
cibao2ner's Avatar
Default heater core question..pic..
while removing teh hose i used pliers and crushed the outlet of the core...didnt know it was so soft...is this fixable any ideas...i can buy a cheap heater core but dont wanna go tru all the trouble of removing dash..etc...n dont want it to leak...any way to bypass it for now in case it leaks?
Old Sep 26, 2011 | 01:34 PM
Julio@Bisimoto's Avatar
Default Re: heater core question..pic..
O man that's the worst just try your best to re-round it and hope that it will not leak.
Old Sep 26, 2011 | 05:09 PM
non-VTEC's Avatar
i did the same stupid mistake.....i took some pliers and tried to round it back as best as possible...not easy but it might work for you also.....slip the hose all the way to the back of that pipe and use a new hose clamp right at the back of the hose....it should be ok.
Old Sep 27, 2011 | 03:14 AM
hondamark35's Avatar
it's worth a shot to try to reshape it to get it to seal up again, but it will be very hard to get it "right."
Old Sep 27, 2011 | 04:40 AM
Gold DA9's Avatar
i did this same thing but flattened it with pliers... tried to reshape it but wasnt happy how it looked, so i bypased it.(no heat) I plan to replace it eventually.
Old Sep 27, 2011 | 06:27 AM
95 integra's Avatar
If you do round it back out, I suggest using some type of sealant to make sure you get a good seal.
Old Sep 27, 2011 | 07:09 AM
fcm's Avatar
fcm
Old Fart
Find something with the same outside diameter as the inside diameter of the "outlet", use it to help roundout the outlet, it does not have to be perfect, as mentioned use a new hoseclamp, slide new hose all the way up to the firewall and and clamp it tight, you should not need any "sealer", but it can't hurt.
We make this repair more then a few times a year, without any problems, 94
Old Sep 27, 2011 | 03:21 PM
Ci-v-iC's Avatar
Let it be a warning for those who tackle the job of taking the heater hoses off.
The best way to remove baked on hoses is to make an incision w/exacto knife along the pipe and peel it off by hand. Hoses cost less than the heater core and one gets peace of mind that they will not fail any time soon after replacement.
As to fixing the pipes, it's a 50/50 chance there will be no leak. Even if there is no leak at first, I can almost guarantee there will be one in the near future.
Good luck anyways.
Nobody123
Sep 25, 2011 10:14 PM
sk8shorty012
Mar 23, 2011 10:53 AM
Corksil
Dec 27, 2009 09:33 AM
.inbou
Nov 29, 2009 11:47 AM
japspecjohn
10
Sep 19, 2004 01:15 PM
