heat wraping intake??
Old Mar 26, 2003 | 08:23 AM
vietshinobi's Avatar
Default heat wraping intake??
i juss got a cold air intake put my GSR, i was wondering if i heat wrap the intake would it do anything?? more power?? where can i buy heat wrap??
Old Mar 26, 2003 | 11:16 AM
PupaScoopa's Avatar
Default Re: heat wraping intake?? (vietshinobi)
Find some insulating wrap (bubble wrap with aluminum on each side) from Home Depot. Then do this:
Old Mar 26, 2003 | 11:55 AM
Tweakmeister's Avatar
Default Re: heat wraping intake?? (PupaScoopa)
sweet
Old Mar 26, 2003 | 12:07 PM
BigZ88's Avatar
Default Re: heat wraping intake?? (Tweakmeister)
Alot of people believe this is going to benefit them a good deal, but if you go with a high quality intake, then you dont have to worry about it. Yea it may look kinda cool when done correctly, but you dont need it. AEM uses aluminum which in itself does not conduct heat verywell, and they use a special paint i believe it is a ceramic coating to further help with this. Iceman uses a plastic that doesnt conduct heat very well, and Injen uses a similar setup as AEM. Just some thoughts. However if u get a cheap intake from say ebay or something and it is thin wall steel or something else, then you may wanna look into wrappingg it.
Old Mar 26, 2003 | 01:21 PM
Ninja Mike's Avatar
Default Re: heat wraping intake?? (BigZ88)
What about a DC DAC intake. Should that be wrapped or is it made not to conduct heat like the intakes stated above?
Old Mar 26, 2003 | 01:42 PM
piotrush's Avatar
Default Re: heat wraping intake?? (MikeBSI)
has anyone ever tried thermotec? I heard its effective on headers, any experiences with intakes?
Old Mar 26, 2003 | 01:47 PM
jansenrw's Avatar
Default Re: heat wraping intake?? (piotrush)
would like to draw this to your attention guys....
A standard motor 1.8 L ( for me). At 9500 rpm thats 17100 Litres of AIR rushing through. Considering this is flowing through a tube of less than 3" it has to be going VERY FAST. Now correct me if I'm wrong but it air does not conduct heat that well ( compared to water but thats besides the point). I'm sure the speed that the air is travelling is too fast to conduct any noticeable differences in temp.
If you are that worried, I think try wrap your headers or HPC them... That's my .02 feel free to flame me if you feel otherwise.
Old Mar 26, 2003 | 01:54 PM
turbochic's Avatar
Default Re: heat wraping intake?? (jansenrw)
i actually have to agree with above, it seems that if you reduce the heat being released from the hottest items in your engine bay, you would be able to keep everything cooler. its not gonna make that big of a difference n-e wayz
Old Mar 26, 2003 | 04:49 PM
crack open your computer...
what's sitting there? an ALUMINUM HEATSINK (which by the way..the more air flow you put over it, the better it cools)
aluminum, next to copper and silver is an IDEAL heat conductor.
the coating AEM puts on helps a little...but wrapping will certainly help a lot.
[Modified by Tweakmeister, 8:50 PM 3/26/2003]
Old Mar 26, 2003 | 04:53 PM
infinatenexus's Avatar
Every little bit helps. I wrapped mine in the home depot bubble wrap,,,,, ghetto
taimysho0
Honda Civic (2006 - 2015)
Mar 22, 2010 06:28 PM
white ej2
Nov 20, 2008 11:10 PM
PinoyCivic
46
May 6, 2006 11:50 AM
JDM_EK3
37
Aug 10, 2004 10:32 AM
intradescant
Jun 13, 2004 04:58 PM
