Heat shield?
Old Jan 18, 2004 | 05:51 AM
99lude's Avatar
Default Heat shield?
What are some of the advantages/disadvantages of removing the heat shield in front of the header??
Old Jan 18, 2004 | 07:10 AM
Kendall's Avatar
Default Re: Heat shield? (99lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lude &raquo;</TD></TR><TR><TD CLASS="quote">What are some of the advantages/disadvantages of removing the heat shield in front of the header?? </TD></TR></TABLE>
Pro: Reduced weight in the front of the vehicle
Con: Potential for higher underhood temperatures in a shorter amount of time
Old Jan 18, 2004 | 10:12 AM
99lude's Avatar
Default Re: Heat shield? (Kendall)
so is it recommended to remove the shield (on a stock car)
or will i be risking any potential damage??
Old Jan 18, 2004 | 10:56 AM
Kendall's Avatar
If the driving you do is primarily highway driving then you should be okay, but if you sit in traffic a lot, then there is the possibility for damage.
Personally, until I get a header, the heat shields stay.
Old Jan 18, 2004 | 11:19 AM
92civeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Personally, until I get a header, the heat shields stay.</TD></TR></TABLE>
MattyP
Mar 21, 2008 07:59 PM
NipTucked
10
Jan 13, 2008 06:35 PM
neo_
63
Oct 20, 2006 04:24 AM
SpoonFedHatch
Apr 26, 2004 02:34 PM
OTT
Mar 4, 2004 04:34 PM
