Head will not seal
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
Head will not seal
i have a D15B7 engine that burnt a valve. i ordered a head from a local yard and installed it myself (no resurface was done), using the triply metal gasket and stock (old bolts), it predictably didn't seal right. in order to fix the issue i have ordered ARP head studs and had the head resurfaced. the head didn't seal again. before i throw the engine away, i would like to see if there is anything i am doing wrong.
suggestions, advice?
Seagull Management
Re: Head will not seal
If it makes you feel any better Ash I don't know of anyone that ever had any luck putting a head gasket in a D15B7/D15B8 I know a couple of people that put 5 head gaskets in one engine before giving up. You can try having the block decked and see if that helps. Honestly I tend to just recommend people pick up a JDM D15B non-vtec or SOHC non-vtec ZC when the head gasket goes in one of these. Btw even if it does seal, they tend to start burning oil very soon after.
I'll just toss in a few things I can think of
Are you torquing the head studs?
Are you torquing them in the right pattern?
Have you checked the resurface to make sure it's all straight? Straight edge check?
1 Post
the head is being torqued down properly. the head was checked after the resurface to be true. i have no idea on the state of the block.
GDD Member
I'm guessing you probably smashed one of the dowel pins or got something else jammed in there.
I sold one of my spare blocks to a guy and he was complaining that my block was bad, so I warrantied it. I checked compression and it was slightly lower in cylinder #1, so I pulled off the head and it turns out he smashed one of the dowel pins and torqued the head down anyway. This is a pic of what he did:
After the dowel pin was replaced, everything sealed up like it should.
Anyway, it only takes about 25-30 minutes to pull a D15B7 head off and even less time if you don't have a/c or power steering. I think it's worth the time to pull it off to see what went wrong.
1 Post
the dowels are seated square, would replacing the completely be a good idea?
I had my d15b7 block and head decked so far so good. Shop guy said the aluminium shrinks away more than the cylinders over time and causes sealing troubles.
Vtec04
Engine Machining & Assembly
11
10-31-2017 09:26 AM
I8ayellowcrayon
18
01-29-2004 11:42 AM
