headlights
Old Dec 9, 2008 | 12:28 PM
Berge9798's Avatar
Default headlights
i have a 96 civic and i just changed the headlights to aftermarket. I have seen some where that you can make it so your low beams stay on with your high beams. i was wondering if anyone knew anything about that
Old Dec 9, 2008 | 06:56 PM
TunerN00b's Avatar
Separate bulbs? If not, don't do it, as you'll melt the plastic housing from the heat (or blow the bulb from running both filaments). If so, use a relay to create a logical OR circuit for the low beams to light when either low or high beam wire sees power.
Old Dec 10, 2008 | 05:49 PM
Berge9798's Avatar
Its 2 different bulbs. i just need to know what wire under the dash i have to pull out so that it will work. I know i have seen how to do it some where
s0biek
Honda Civic (2006 - 2015)
Jun 1, 2012 03:23 PM
cheetah64
Oct 18, 2004 08:31 PM
User 5426
Feb 9, 2004 10:08 AM
