Head studs with no lube?
Old Apr 22, 2007 | 12:35 AM
midnitesol's Avatar
Default Head studs with no lube?
i installed the studs with no lube. Will this be fine or do i need to redo it. Also does anyone know the torque specs for the cam holders, my manual says 20 ft/lbs but one of the bolts snapped, input greatly appreciated.
Old Apr 22, 2007 | 04:10 AM
NJIN BUILDR's Avatar
Default Re: Head studs with no lube? (midnitesol)
The lube is required for correct torque values.
Old Apr 22, 2007 | 10:59 AM
midnitesol's Avatar
Default Re: Head studs with no lube? (NJIN BUILDR)
F***! any one else? I really dont want to buy a new head gasket if i don't have to.
Old Apr 22, 2007 | 11:04 AM
Flashmn's Avatar
asking again wont yield other answers, you're supposed to lube them to get them properly tightened.
Old Apr 22, 2007 | 11:08 AM
midnitesol's Avatar
Default Re: Head studs with no lube? (Flashmn)
I wasn't expecting a no I was just looking for ne one else that had done this and also to see if ne one knows the torque specs for the cam holders cuz i cant find them anywhere.
Old Apr 22, 2007 | 11:33 AM
00Red_SiR's Avatar
All Motor Mentor
If you never oiled the threads before torquing them, the torque specs will probably vary a little. Is it the end of the world? no. Yes you should oil them before you torque them just like you should only use head bolts once but people have used them more than that and been fine and I'm sure lots of people have forgot to oil the threads before installing them. You should do it properly but I'm sure you'll be fine if you didn't oil the threads.
As far as torque specs go, what does your manual say? Depending on what your car year and model is, you can cross reference it with information from here to check for accuracy:
http://spoonhonda.com/downloads.htm
Old Apr 22, 2007 | 12:08 PM
midnitesol's Avatar
Default Re: Head studs with no lube? (00Red_SiR)
Thanks a bunch for everyone's help.
in9teg2ra
Apr 23, 2009 06:31 PM
95teilhatch
Jun 25, 2007 01:20 PM
Jdmb16sir2
Jun 10, 2007 05:50 PM
high_revs
Jun 6, 2005 04:34 PM
xXx Justin xXx
Apr 1, 2004 07:20 PM
