Head Gasket Question
Old Mar 24, 2008 | 06:51 PM
Da9_Rider's Avatar
Default Head Gasket Question
Ok i did some research but didn't find enough info so here is my question :
B18c block overbored to 84mm what head gasket do i use ?
The B18c one is 82mm if im not mistaking. Since the B20 is 84mm i was thinking of using that head gasket but not sure about it ...
The other thing i read up on is that some people use oem 82mm and cut them out to the desired bore... if that's a good method how do you guys cut it out so its perfect ?
I know there is COMETIC head gasket but my question is does a b20 head gasket better if it fits on a b18c block ? this i for a turbo set up aroud 350-400 whp
thanks
Old Mar 24, 2008 | 08:10 PM
inspyral's Avatar
Golden Eagle makes overbored OEM headgaskets. I wouldn't use the B20 one since the rivets can interfere with the head and one of them usually has to be removed to use a non-VTEC headgasket with a VTEC head. You could use a Cometic gasket, but the OEM gaskets are great, and a lot of people(myself included) swear by them.
Old Mar 25, 2008 | 10:05 AM
all-mtr-teg's Avatar
Default Re: Head Gasket Question (Da9_Rider)
GE or Cometic
Old Mar 25, 2008 | 02:49 PM
Da9_Rider's Avatar
ok thanks i found the info i needed thanks for ur posts
94sihatchy
Jun 15, 2008 12:40 PM
freakin
Mar 5, 2005 09:03 PM
westcoaststyle
Jun 11, 2004 05:51 AM
dbman96
May 27, 2002 09:19 AM
dbman96
May 24, 2002 11:23 AM
