head gasket.... break in?
Old Feb 22, 2003 | 09:16 AM
servion's Avatar
Default head gasket.... break in?
I just changed my headgasket (to an OEM honda one).... is there any form of breakin?
Also, I've been using mobil 1 full synthetic 15w50.....do I need to go to a natural non-synthetic motor oil first, or can I jump right back to the mobil-1?
Old Feb 22, 2003 | 09:39 AM
TimoneX's Avatar
New User
Default Re: head gasket.... break in? (servion)
There is no break in on a headgasket, if that's all you changed.
Old Feb 22, 2003 | 11:48 AM
servion's Avatar
Default Re: head gasket.... break in? (TimoneX)
I changed the valve seals, resurfaced the head, and all the top-end gaskets.
Who about motor oil? Am I safe to go striaght back to synthetic?
Old Feb 22, 2003 | 11:54 AM
TimoneX's Avatar
New User
Yeah I'd go right with whatever oil you like.
Old Feb 23, 2003 | 05:53 PM
Jason.H.'s Avatar
no break in would be needed go strait to ur choice of oil and make sure u idle ur car for about 5 minutes to let the oil circulate then u should have no probs
Old Feb 23, 2003 | 06:50 PM
servion's Avatar
Default Re: head gasket.... break in? (hondagod)
cool... I finished it today and did exactly that.... no leaks so far!
Old Feb 24, 2003 | 05:03 AM
TimoneX's Avatar
New User
Kewl bro. I'm jelous I won't have my go-kart back together for another week or two.
Old Jul 14, 2003 | 02:36 PM
servion's Avatar
Has anyone ever heard of a headgasket leaking at first and then 'seating'... or something to that extent? I.e., you install a new gasket.... it has a leak for a few heatcycles and then goes away?
Old Jul 14, 2003 | 02:40 PM
slowdx's Avatar
Never heard of that..i just changed my headgasket....you may see some random coolant and such in wierd places due to if your head gasket blew coolant went everywhere...just clean you engine bay real good.im sure u flushed your coolant right? well if not do that the check and make sure there are no leaks...
Old Jul 14, 2003 | 05:59 PM
servion's Avatar
Default Re: head gasket.... break in? (slowdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx &raquo;</TD></TR><TR><TD CLASS="quote">Never heard of that..i just changed my headgasket....you may see some random coolant and such in wierd places due to if your head gasket blew coolant went everywhere...just clean you engine bay real good.im sure u flushed your coolant right? well if not do that the check and make sure there are no leaks...</TD></TR></TABLE>
Yeah,,,, its definitely the HG.... and I was afraid that mypresumtion wa correct (no seating or break-in)..... has anyone ever heard of this or had such a leak that stopped after a few heat cycles?
Old Jul 14, 2003 | 08:00 PM
slowdx's Avatar
My previosu post sounding like rambling sorry. I was in a hurry. But after i changed my head gasket i thought it was leaking because after parking my cari would see a tiny puddle on the ground under the motor. It was coolant. I thought i had a leak but i cleaned my engine out real good drove it around anfd let i tdry then parked in in the driveaway and no more drips i twas jsut remannts of coolant and such from the instal and or blowing of the headgasket. Maybe thats what you think is a leak.
Is there white smoke coming out your exhaust..Well drive it a little first there could still be coolant or oil or something in your header from when it blew drive it a little first..and check your coolant level freguently.
But no i have never heard of leaking then it stopping after a few heat cycles.
joetho
Jan 10, 2008 03:19 PM
Fat Chick Magnet
Jan 1, 2008 11:59 AM
PatrickGSR94
Mar 5, 2003 10:02 PM
OldSchoolCrxSiR
13
Jun 26, 2002 09:41 PM
