having problems rotating crank while doing valve adj.
Old Jul 3, 2003 | 11:03 AM
bartek_b's Avatar
Default having problems rotating crank while doing valve adj.
ok, guys I got the first cylinder done, I set it to TDC, and I'm moving onto Cylinder 3. When I try to turn the cam geat 90 degrees to the next spot, my bolt from the came gear comes undone and I can't move it.
I have tried to crank the engine to get it into the right spot, but that isn't working out.
Any Ideas how I can turn the came gear without un-doing the bolt???
thanks
bart
Old Jul 3, 2003 | 11:26 AM
StyleTEG's Avatar
Default Re: having problems rotating crank while doing valve adj. (mugen85r)
your supposed to rotate it from the crank pully bolt, not the cam gears.
Old Jul 3, 2003 | 11:32 AM
IN VTEC's Avatar
Remove the spark plugs and take it out of gear. That should make it easier.
Use a longer lever arm. A little 8" long 3/8" drive ratchet only gonna make life harder.
Check your crank/cam timing mark alignment after you're done. You may have skipped a tooth or few.
Old Jul 3, 2003 | 12:31 PM
bartek_b's Avatar
Default Re: having problems rotating crank while doing valve adj. (IN VTEC)
ok, the car was in Nutral, and didn't have spark plugs in it.
I got that done. I just turned the cam gear counter-clockwise, but when I first started, I was scared no to snap-off the bolt.
ok, here's my latest problem
I done all the vavles to the exact specs in my haynes book and I tightend all the bolts, put on the valve cover and started-up the car.
All I hear is a ticking noise....and i'm scarred I fucked something up(first time doing vavle adjustment).
I turned it off imediatly.
Is it possible that I bent a valve(s)?
Old Jul 3, 2003 | 01:36 PM
bartek_b's Avatar
Old Jul 3, 2003 | 02:22 PM
drumking15's Avatar
you sound like me...make sure you did the valves to the tighter end of the specs...double check and triple check....to me 3 valve adjustments to get it right
Old Jul 3, 2003 | 04:51 PM
IN VTEC's Avatar
You either didn't tighten down the lock nut(s) properly - if the ticking is more like a tapping, or the clearances are too loose - do it over again.
Use the next biggest feeler gauge to double check your clearances.
Old Jul 3, 2003 | 05:45 PM
Yougod's Avatar
when you tighten valves, your engine should be louder. valves wear tight... not loose. that's the reason why we don't adj. valves @ 90k unless the customer states they want it done. they seem to complain that it's louder... which is normal.
dleccord
Jan 12, 2010 06:33 AM
obuhmyuh
Jun 8, 2008 09:38 AM
AnotherEJ
Mar 29, 2008 04:40 PM
houstondigital
Aug 10, 2005 12:26 PM
THE *FOB* MOB
Aug 14, 2002 07:42 PM
