Having problems with the d15.
Old May 6, 2007 | 07:11 PM
Laosakademiks's Avatar
Default Having problems with the d15.
ahh yes..another one of these threads. but on a serious note, my car is acting up pretty bad so heres the story...
yesterday, it was raining pretty hard over here in tennesee. i went on this one road and literally drove through a feet or two of water. i started to drive home about 3 miles and everything was fine. as soon as i pulled into my neighborhood..it felt like it was running on 3 cylinders. i popped the hood and to no suprise, spark plug wire for #1 came off. plugged it in..and it didnt start.
i checked all the fuses both under the dash and in the engine bay. i have fuel, i have spark, and compression also.
and to my surprise..it started once every blue moon. for example, i would try to start it for about 2 minutes, and then itll start. and when it does start, it runs like crap. i tried to drive it and it cut off, and wouldnt come back on.
at first, i was almost certain i wasnt getting fuel because my fuel pump wasnt priming but then itll randomly cut on so i pushed the main relay, and the fuel pump cuts on every time now. but it didnt solve my problem.
also, i changed my ecu with a p28 because my carpet was wet. whats funny is im throwing a code. its number 19, automatic transmission lockup control valve. i am running an auto ecu because my car used to be auto. but i converted it to manual and it was running fine for the past 5 months and no cel until i was driving home that day.
could it have hydrolocked? thats what i thought...so i took the head off and cleaned the cylinders but there was no water. i was going to take the spark plugs out and crank it a couple of times but couldnt because the little rub piece came off my spark plug wire and got stock around the spark plug which pwns me when trying to put a socket down there. ill try it tomorrow and see what happens.
so as you know...i tried a lot of things before posting hoping itll work but none did. does anybody have any clue, any help would be great. or should i go to plan b and drop the ls back in my car.
Old May 6, 2007 | 07:14 PM
Default Re: Having problems with the d15. (Laosakademiks)
and btw...compression was 150 on #3 and #4. couldnt do #1 and #2 because i cant get the spark plug out.
Old May 7, 2007 | 04:22 AM
bump before i go to school.
Old May 7, 2007 | 05:08 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
what do you mean you can't get the spark plugs out? get them out somehow. use a ghetto bar for leverage if you have to.
Old May 7, 2007 | 06:15 PM
Default Re: (full Circling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean you can't get the spark plugs out? get them out somehow. use a ghetto bar for leverage if you have to.</TD></TR></TABLE>
i ment that the socket wouldnt go on because a rubber piece came off the spark plug wire and got stuck around the spark plug.
but guess what..i have no idea why but i started it when i came back from school and it fired right up. runs fine. i didnt do a thing to it but in no way am i complaining. maybe something dried up in the sun?
Old May 7, 2007 | 09:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laosakademiks &raquo;</TD></TR><TR><TD CLASS="quote">
..felt like running on 3 cylinders.
spark plug wire #1 came off.
didnt start.
fuel, spark, and compression.
try to start it for 2 minutes, then itll start.
runs like crap.
tried to drive
cut off, wouldnt come back on.
took the head off
no water.
was going to take spark plugs out
should i go to plan b and drop the ls back in my car.</TD></TR></TABLE>
take a pair of needlenose pliers and get that rubber piece off the plug. replace your plugs and wires. as for the ecu, i don't know, but personally, i would get a somewhat reputable tuner to at least check it out. did you get the ecu converted from auto to manual when you did the tranny swap?
Old May 7, 2007 | 10:05 PM
Default Re: Having problems with the d15. (full Circling)
everything is fine now. and when i was driving, the cel randomly went away. thanks anyways
kaputhonda
May 28, 2013 11:56 AM
ef roni
Nov 12, 2008 10:34 PM
JKingCivicSi
14
Apr 18, 2008 07:24 AM
vinuneuro
Oct 12, 2006 05:44 AM
OrangeBoost
Jun 30, 2006 09:15 AM
