hardly any brake
It's a 97 civic hatchback. With the cx motor it was braking fine but right after swapping to a b18c the car can hardly brake (pedal is all the way at the bottom). I was just wondering what you guys think it could be. So far I've bled the brakes at all 4 wheels (used those big bottles of brake fluid), bled the master cylinder, and checked the vacuum hose. Brake pads are still good. Thanks.
Isn't this how you test the brake booster??? ---> Pump brake pedal several times with engine off, hold pedal, start motor, and if the pedal goes down then the booster is good.
[Modified by hmonglonertim, 10:00 PM 4/23/2002]
You use the term "brake pads"...
The 1997 Civic HB has rear drum brakes...did you change the rear drums to a disc brake setup?
The vacuum booster and master cylinder on disc/disc cars are different from disc/drum cars...disc/drum cars need a residual check valve in the rear.
In any case, the b18c motor comes from a disc/disc ITR?
Many possibilities...how car is Clearwater from Fort Lauderdale?
-Andie
-Andie
I think clearwater is pretty far from FTL... Sounds like a dying master cylinder... does the car still slow/stop when you floor the brakes ? Do you have to press HARD to stop ?
Front has disc and rear has the drum brakes. The car will stop but you will have to let go after the brake pedal sinks all the to the floor and depress the brake pedal again for better braking. Brake hoses look fine, sliders on capliper are good. Ft Lauderdale to Clearwater is somewhere around 2.5 to 3.5 hrs. I have no clue what's up. Could it be a bad master cylinder? Thanks for your help.
[Modified by hmonglonertim, 11:27 PM 4/25/2002]
i have the same problem.....if i brake all the way my brakes will lock....inorder to get a good brake ill have to pump the brakes b4 it locks up....i think the master cylinder is dying not sure, done everything esle....
If the initial brake is soft and sinks, then comes up after a couple of pumps, then it is air. When the master goes, the pedal will constantly go to the floor on each pump
How did you bleed the brakes. That should be your problem.
i just had the same problem with a 94 integra. when i hit the brakes the pedal would have some pressure, but then would go to the floor. I had a friend hit the brakes while i was under the hood and i could hear air leaking from the master or booster, one of the two. I replaced both and have no more problems. cost from a wrecking yard for both was $60
One more question. Should I get a cx master cylinder or a b18c master cylinder. If I was to get the the cylinder from the b18c would I have to get anything else done to the brake system. Thanks for the help.
jdm_ek_noob
Apr 3, 2015 08:40 PM
