Handling!!!
Old Jun 18, 2002 | 10:08 AM
Turbo Powa's Avatar
Default Handling!!!
Ever since I got my civic I'm been getting shitty handling. I'm starting to notice crappy handling and I dont have a strut bar, tie rod or sway bar. What should I do? SHould I get one of the above? Will it improve my handling alot better? Which companies do you recommmend?
Old Jun 18, 2002 | 10:27 AM
Spade's Avatar
Default Re: Handling!!! (Civic LX 29)
Springs first, then sway bars, then strut bars........I went springs, strut bars but.....I would say go with springs then sways then struts.
Old Jun 18, 2002 | 10:31 AM
Acronym's Avatar
Default Re: Handling!!! (Spade)
Any order just get them all!!!!
Old Jun 18, 2002 | 10:46 AM
Daemione's Avatar
Default Re: Handling!!! (Acronym)
It sounds as if your handling is getting progressively worse, which would point to your shocks. How old are they?
At least get it handling as good as stock before you try band-aiding other areas to compensate.
Old Jun 18, 2002 | 10:54 AM
Crazydave's Avatar
Default Re: Handling!!! (Daemione)
Check your shocks..
get the car bouncing... then stop bouncing it.. and see if it stops right away.. if it doesn't you need shocks..
also check your tire pressures... they should all be around 28psi
if these are all ok..
I would sugguest some good tires and shocks.. maybe some springs...ground control with koni adjustables are popular combo
tires is a huge argument but aggreed that sticky tires are better than stock tires
Old Jun 18, 2002 | 11:27 AM
Turbo Powa's Avatar
Default Re: Handling!!! (Crazydave)
Whats the cheapest but most effective products? I'm on a very low low budget.
Old Jun 18, 2002 | 11:39 AM
Daemione's Avatar
Once again, find out if you need new shocks first. New ones from the dealer are probably $60 a piece or more. Though you can probably get mild aftermarket replacements for cheaper (Koni Reds, Tokico blues, KYB GR2's, Bilsteins).
Or you could find someone's used Civic Si or Integra shocks for cheap - they'd be better than what you've got now. A lot better, if yours are blown.
Old Jun 18, 2002 | 11:44 AM
Turbo Powa's Avatar
There not blown. There still good. It just feels like its getting shitty every week. Maybe its just me? Should I try tie rods?
Old Jun 18, 2002 | 11:50 AM
Crazydave's Avatar
no prob not tie rods..
shocks and springs will make a big difference
Old Jun 18, 2002 | 12:25 PM
Turbo Powa's Avatar
thanks!!
Old Jun 18, 2002 | 03:04 PM
Lsos's Avatar
If you're on a low budget, I suggest sway bars (or just a rear one). It'll make a huge difference. Springs require shocks and all that. They'll just be more expensive.
As for your handling getting shitty, it probably is just you. If you do any proper mod to your car, you'll notice the first week what a huge difference it made. "Wow, that extra 200hp really made this car go!" or "That racing suspension really makes this thing turn!".
A week later it'll feel sluggish, slow, and it will turn like a battleship. That's when you get a bigger turbo, stickier tires, or the cheapest way is just drive almost any domestic for a week. My Galant feels like a race car compared to this Buick I once drove.
Old Jun 18, 2002 | 04:27 PM
Turbo Powa's Avatar
Default Re: Handling!!! (Lsos)
Thanks!!
crichardw
Suspension & Brakes
Dec 19, 2017 03:39 PM
stpacura
Feb 2, 2006 08:10 PM
turbo4racing
52
Jun 13, 2003 01:29 PM
CaMiKaZi
Apr 21, 2003 08:00 PM
Prelussion
14
May 1, 2002 03:43 PM
