H23a fuel pump issue
Old Feb 26, 2016 | 08:04 PM
Tyler Edge's Avatar
Default H23a fuel pump issue
OK guys I just did a h2b swap in a eg hatchback and I had it running and drove it two miles and began to drive like crap, needles to say I did some replacing in parts to try and narrow it down. I have replace the fuel pump, main relay, and ecu. And the fuel pump is still not priming I'm wondering if it's the wiring harness which also looks like crap and was ment for a tuck bay, any ideas?
Old Feb 27, 2016 | 04:08 AM
v4lu3s's Avatar
RTFM
Default Re: H23a fuel pump issue
How does your fuel pump ground look?
Old Mar 12, 2016 | 08:36 AM
Tyler Edge's Avatar
It was good, it was the main fuse under the dash, but still won't fire up. I'm getting spark, fuel pump is priming, compression on all 4 cylinders were 200 plus, I've check the ground to the themostat, valve cover, alternator, and the mine ground to the fuse box in the engine bay. Only code I am throwing is code 21, also has new dizzy, plugs, and wires. I have no idea why it's not firing up..... running out of ideas lol.
Old Mar 12, 2016 | 02:28 PM
motoxxxman's Avatar
what ecu are you using?
user 72830283
21
Apr 23, 2020 12:38 PM
zippakilla
Feb 6, 2009 04:01 AM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
94delsol6428
Dec 27, 2006 07:06 PM
