H22a from scratch Any suggestions??
My Block is floating in the hot tank as we speak. Any suggestions as far as the bottom end? ie; knife-edging and micropolishing crank,chamfered oil passages, piston and rod suggestions, who makes the best sleeves(benson's?)? The motor will be boosted to the tune of 18-22 psi. Thank for all the help.
DO NOT KNIFE EDGE!!!!!
All professional racers don't knife edge there cranks!!!! It will unbalance the crank shaft!!!!
Golden Eagle makes the best sleeves. http://www.goldeneaglemfg.com
They can also get a good deal on forged pistons.
I suggest you consult golden eagle for your application.......
do not micropolish either. tahts is the dumbest thing in the honda world to do
the cranks are tuffriddin they are soft with a hard coating over them if you grind the crank doen you will kiss your bearings good bye.
djnikko
Jun 16, 2005 04:23 AM
HotWheelz
Nov 23, 2002 07:43 AM
