H22 vs. B Series Weight
I am trying to determine the weight difference between a H22 longblock and a B series longblock (B16 and B18c). Did a search and found results comparing the shortblock weight and tranny weight, but cant find anything that compares the longblock weights. If anyone has this info handy, please let me know.
I am basically trying to figure out the approximate weight of my H2B setup vs. a typical B16/B18 swap.
Thanks,
-J
Thanks,
-J
you know it....
94-96 (GSR) B18C Engine
Swap: $3085.00
-Only long blocks in stock currently $1850.00 & Completes w/ LSD $3300.00
� 1800cc (1.8L) DOHC Vtec engine.
� 180hp/126trq, 10.6 compression ratio. (U.S. version has 170hp and 10.1 cr.)
� Hydro tranny type.
� P72 OBD-1 or OBD-2 ECU equipped.
� Inquire within for LSD equipped trans. (not all trans are LSD equipped).
97-00 (GSR) B18C Engine
Swap: $3600.00
-Out of stock
� 1800cc (1.8L)DOHC Vtec engine.
� 180hp / 126trq / 10.6 compression ratio. (U.S. version has 170hp and 10.1 cr.) � Hydro tranny type.
94-98 Integra Type- R Engine
Swap: $4800.00
-Out of stock
� 200hp / 18.5Nm trq / 11.1 cr., DOHC Vtec (U.S. version is 195hp/10.6 cr.)
� Integra-R P73 OBD-2 ECU type.
94-98 Civic R (B16B) Engines
Swap: $4600.00
-Out of stock
� 185 hp / 118 trq / 10.8 cr., DOHC Vtec Engine.
� Civic-R PCT OBD-2 ECU type.
92-95 Prelude H22A Engine
Swap: $2250.00
� 2200cc (2.2L) DOHC Vtec Engine
� 200hp / 161trq / 10.6:1 cr.
� Hydraulic tranny type
� Inquire within if you desire the U.S. version of the this engine.
96-00 Prelude H22A Engine
Swap: $3100.00
-Out of stock
� 2200cc(2.2L) DOHC Vtec.
� Inquire within if you prefer the U.S. version of the this engine.
Swap: $3085.00
Swap: $3600.00
-Out of stock
Swap: $4800.00
-Out of stock
Swap: $4600.00
-Out of stock
Swap: $2250.00
Swap: $3100.00
-Out of stock
h22ame
10
Apr 8, 2004 09:09 PM
