h22 turbo timing
Old Mar 26, 2004 | 07:32 PM
b16hybridsol's Avatar
Default h22 turbo timing
i finally got all my stuff, situation is i can't get it tuned untill the end of april, i'm running the hack with 450s, and using the p30 out of my del sol vtec. i'm tryin to get ahold of a wideband to tune it for now, but what should i do about timing, i don't understand where people are getting these degrees from, i've got a light, and my motor is in time, but how should i retard it, and how much
Old Mar 26, 2004 | 07:41 PM
Default Re: h22 turbo timing (b16hybridsol)
oh i forgot, the reason i want to use the wide band is because i have the vafc set at -10 took it around the block and the plugs are still grey, should i just keep richining it up or is there an easire way to do it
Old Mar 26, 2004 | 08:31 PM
?? i just want to retard it like 3 degrees, how do i know how many degrees i'm moving
Old Mar 5, 2006 | 07:21 PM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">?? i just want to retard it like 3 degrees, how do i know how many degrees i'm moving</TD></TR></TABLE>
are you using a timing light?
3 deg retarded at the distributor is gonna make the car run like Poo probably when you are off boost, but better safe than sorry..
Old Mar 6, 2006 | 12:58 AM
Default Re: h22 turbo timing (GaRn)
holy **** man, this is from like 2 years ago...i had a cheap *** light at the time that wasn't a dial by degree style.
but thats all long sence gone, bigger turbo, aem ems, etc.....
95EG2
Jun 3, 2011 11:25 AM
Nataku
Dec 27, 2006 07:04 PM
darockstar
Mar 25, 2006 12:35 AM
The Jacko
Jun 22, 2005 12:07 PM
Sabbotage
Nov 8, 2004 04:47 PM
