H beam vs I beam rods
Two way to achive the same goal.The are good rods in both styles.The Pauter rods are kind of a + style cross section.I think the H beam probably gives the most strength per pound.
From what I have been told at my machine shop is the H beam is stronger, the I beam is lighter (typically). I went with I beams since they will support far more power than I will make on an all motor setup with the possibility of spraying. For me a lighter rod is better. In the end between my rods and pistons I ended up shaving off 100-125 grams PER rod/piston assembly, which is about 1 lb off the rotating assembly.
silverskateEF9
31
Oct 6, 2007 07:13 PM
johncarlos
May 1, 2004 02:51 AM
