Gut the AC
Old Apr 24, 2003 | 02:22 PM
RISING SUN 1
Guest
Posts: n/a
Default Gut the AC
I have a 93 cx hatch and am guting it, I have taken all the a/c stuff out and off the engine bay but just wondering what things i have to remove from the cab, like ducts and or box's. I see alot of black housings under the dash.
anything will help thax
Old Apr 24, 2003 | 03:02 PM
untitled's Avatar
Default Re: Gut the AC (RISING SUN 1)
you still need those for your heater and shtuff to work. pull the carpet and scrape the tar and sound deadener off.
Old Apr 24, 2003 | 03:04 PM
RISING SUN 1
Guest
Posts: n/a
Default Re: Gut the AC (88crx91integra)
did every thing is out exept **** under dash
Old Apr 24, 2003 | 03:17 PM
untitled's Avatar
Old Apr 24, 2003 | 03:33 PM
91DA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">you still need those for your heater and shtuff to work. pull the carpet and scrape the tar and sound deadener off.</TD></TR></TABLE>
Actually the heater core is seperate from the evaporator. They are housed in the same box though.
If you really want to do this you will have to completely remove your dash and then most of the HVAC system. When you have enough ductwork removed to open the large box with the heater core/evaporator you can remove the evaporator. It is the one with a probe looking thing on it. It also should have metal fittings on it instead of rubber hoses. You will have to find a way to plug up where the fittings came in for the evaporator or it will blow air into your engine compartment. Not really a big deal if you really want to do it half assed.
dns92civhatchcx
Feb 5, 2013 06:43 PM
silverdcteg
Mar 17, 2010 07:10 AM
alex_s817
Jul 1, 2007 11:45 PM
DarkBB4
Mar 28, 2007 08:07 PM
[ iLL ] iNt3GrA
May 23, 2004 05:33 PM
