difference between AT and MT ECU
Old Apr 24, 2003 | 10:40 AM
5STAR3's Avatar
Default difference between AT and MT ECU
how can you tell the diff. between an AT and MT ecu?
Old Apr 24, 2003 | 11:08 AM
eg6ajk's Avatar
Default Re: difference between AT and MT ECU (envision2teg)
depends on the type of the ECU but usually by the barcode sticker.
such as 37820-P30-901 = auto
last three digits determine whether its auto or 5spd.
auto= J50/j51/j52/900/901/902/N51/N50 and so on
Old Apr 24, 2003 | 11:40 AM
5STAR3's Avatar
Default Re: difference between AT and MT ECU (eg6ajk)
ok, specifically a p75 obd-1 ecu. thanks.
Old Apr 24, 2003 | 01:17 PM
Katman's Avatar
plug the ecu into an OBD1 car and see if you get a CODE 19 cel....code19 = lock solenoid on AT trannys.
Old Apr 24, 2003 | 02:16 PM
5STAR3's Avatar
Default Re: difference between AT and MT ECU (Katman)
i would but i am buying it from someone on the internet and he thinks its auto but doesnt know for sure. there is no code????
Old Apr 24, 2003 | 03:40 PM
Katman's Avatar
there is a code....but I'm not too sure what is for the P75 ecu.....Try eg6ajk's suggestion or get the owner to put the ecu in his car and check for code 19.
panaphobic
May 6, 2008 07:25 PM
panaphobic
May 6, 2008 11:48 AM
PACT man
Jan 16, 2007 08:46 AM
