GSR block with LS crank.
Old Jan 19, 2002 | 02:00 AM
B18C-EJ1
Guest
Posts: n/a
Default GSR block with LS crank.
Ok, time to do some thinking, I'm going to be rebuilding my GSR due to major rod bearing failure. So here are my options.........
GSR block, LS crank, LS rods, .25 over ITR pistons.
Total displacement = 1857cc ( I think )
Now, what's the force exerted at the crank on the LS rods. Would it be better to just use the LS rods, or go for some Eagle units.
I believe maximum revs should be just under 10k.
GSR crank = 87.2mm
LS crank = 89mm
Difference in rotation .9mm
Lastly, I can also go with GSR rods, and CTR .25 over pistons. Would the difference of -.9mm drop the c/r too low? Or is it just a waste of $$ to do this?
Thanks.
Old Jan 19, 2002 | 05:17 AM
rainforest's Avatar
Default Re: GSR block with LS crank. (B18C-EJ1)
still can't do it unless you get ls rods and they suck.
Old Jan 19, 2002 | 05:24 AM
rainforest's Avatar
Default Re: GSR block with LS crank. (rainforest)
also you want a moor that revs you wont get that out of the 1.53 r,s of the ls stick with the 1.58 of the gsr. or just bore and sleeve a b16a.
Old Jan 19, 2002 | 05:56 AM
FSTASNTZ's Avatar
Get the Eagle rods, the LS rods are just not going to take it...
As for RPMs, get it balanced, should be just fine. I have not really beat on mine yet (not tuned yet), but it is a difference in torque down low...
Jason
Old Jan 19, 2002 | 11:41 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: GSR block with LS crank. (FSTASNTZ)
Yea, that's what I was thinking too. The LS rods are ok for low revs, but once you get past 8k, they start to go to hink I'm going to get the Eagle rods.
Old Jan 19, 2002 | 08:34 PM
sgT's Avatar
sgT
you cant use factory pistons with aftermarket rods.
if you do you will have to have the piston modified.
Old Jan 19, 2002 | 11:45 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: GSR block with LS crank. (sgT)
To make the piston a floating wristpin?
1991islsv
Nov 21, 2008 07:25 PM
TurboEH2
Apr 2, 2005 11:15 AM
electric_rex
Dec 5, 2004 02:57 PM
NathanMorris
Nov 30, 2004 10:01 AM
svmnredracr
Sep 28, 2004 07:46 AM
