gsr rebuild please help
Old Jul 26, 2010 | 04:10 PM
R3PT4R's Avatar
Default gsr rebuild please help
Hey guys i just got my block back after a spun bearing put it out of comission well anyways the crank is still good and he turned it to a .010 and balanced it for me and bored my cylinder walls to a .020 from standard so my question is will this be enough to rebuild my motor completeley...
GSR rebuild project
ACL race bearing kit main rod and thrust $100 modern automotive performance
Full gasket kit $170 rock auto
Wiseco piston and manley rod set $780 rsp (407)-695-race
Type r oil pump $104 ebay
water pump $36 rock auto
Timing belt $22 rock auto
total $1272 in parts
my budget was $1400 and ive already pushed it a bit with the machine work but i figure if im in there lets do it right so would this be good for a future bolt on turbo? my HP goal is 300-350
im going to assemble the motor myself so there will be no cost there besides getting he pistons hung i just need to know if this is everything i need cause thats all i have enough money for now and i need to get my car back on the road, and will i push those numbers reliably with that setup?
also
* i haveskunk2 pro series IM, port matched throttle body, buddy club adjustable cam gears, buddy club spec 2 camshaft, buddy club p1 valve train, and my head is ported for better airflow
Old Jul 26, 2010 | 04:16 PM
Eclectia's Avatar
Default Re: gsr rebuild please help
You'll need some new rings, and a new timing belt tensioner if you don't have them already. Wether or not this will be a good turbo setup depends on the compression ratio of those pistons. Do you know what it is?
Old Jul 26, 2010 | 05:49 PM
boostedeg302's Avatar
As long as the pistons are low compression, then it will be great for turbo. The only thing I see wrong with this list is the cams. They will not be good for forced induction. You will need a tune in order to run this engine safely.
Old Jul 26, 2010 | 06:51 PM
R3PT4R's Avatar
the pistons are 9.7.1 - 10.2.1 heres the link and yes they have rings
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_3878wt_753
i havent ordered them yet so i can go with lower if need be and do you think i should go with the stock cams? i still have them
jdm201010
Aug 17, 2013 11:37 AM
boostedefhatch
Apr 5, 2009 11:34 PM
knuckk
Jan 21, 2008 02:09 PM
birz
Mar 1, 2004 03:30 PM
