GSR Hybrid question. help
Old Sep 15, 2004 | 08:37 AM
92-LS-Civic's Avatar
Default GSR Hybrid question. help
i have tried many different words to try and search for what i am trying to figure out. If i could just be told or give me a link to where it says this it be great. I am trying to figure out what axles i need for my 93 civic hb with the gsr motor swap. also what motor mounts i need replace with integra ones. thanks. and please dont just say search. i cant find this damn question.
Old Sep 15, 2004 | 08:53 AM
dfoxengr's Avatar
Default Re: GSR Hybrid question. help (zdowell17)
search man. im sorry but thats a mickey mouse ? thats covered all the time. im going to be a dousche and tell you that i know, but tell you to find out for yourself.
funny i searched one word in one certain forum on here and found like 10 thread regarding this.
"swap" in "eg civic forum"
Old Sep 15, 2004 | 09:01 AM
Default Re: GSR Hybrid question. help (hybridvteceg)
its not that the seach came up with nothing. i just cant search and find what axles i will need with my gsr swap into my 93 civic hb. im still trying.
Old Sep 15, 2004 | 10:33 AM
Crazydave's Avatar
you also check out
http://tech.hybridgarage.com/
Old Sep 15, 2004 | 10:45 AM
dfoxengr's Avatar
Default Re: GSR Hybrid question. help (Crazydave)
like i said. i found it on this site in under 2 minutes
Old Sep 15, 2004 | 01:04 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
94+ integra axles
Old Sep 15, 2004 | 03:37 PM
gotjesus's Avatar
Default Re: GSR Hybrid question. help (HOOKUPS)
actually, 90-00 integra axles will work .
Old Sep 15, 2004 | 04:19 PM
sol_guy8569's Avatar
Default Re: GSR Hybrid question. help (Teamsteadfasthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamsteadfasthatch &raquo;</TD></TR><TR><TD CLASS="quote">actually, 90-00 integra axles will work .</TD></TR></TABLE>
I believe that he is right. They should work.
Old Sep 15, 2004 | 04:23 PM
DYNO-PRO
ACTUALLY YOU ARE WRONG IF HE HAS A gsr CONVERSION THEN HE HAS THE MALE HALF SHAFT SO HE WILL NEED 92+ INTEGRA AXELS THE 90-91 USE A FEMALE 1/2 SHAFT WHICH MEANS THEY HAVE A MALE END ON THE DRIVERS SIDE AXEL
Old Sep 20, 2004 | 08:04 PM
gotjesus's Avatar
im not trying to judge your knowledge. he simply said he had a gsr swap in his hatch. 90-00 axles WIIILLL bolt right in buddy. ive been doing this for years!!!!
Old Sep 21, 2004 | 09:05 AM
damnit this is confusing, ok can i or cant i use 94+. because didnt in that year the transmission changed from cable to hydro? please lets clarify this please
Old Sep 21, 2004 | 09:50 AM
DYNO-PRO
OK IVE BEEN DOING THIS FOR QUITE SOME TIME ALSO if you are using a cable trans then u will need 90-91 integra axles, if you are using a hydro trans (which you should be) then you will use 94+ axles....PERIOD
Old Sep 21, 2004 | 10:50 AM
thanks for clarifing. also what motor mounts do i need? 94+ integra all of them?
Old Sep 21, 2004 | 10:58 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">OK IVE BEEN DOING THIS FOR QUITE SOME TIME ALSO if you are using a cable trans then u will need 90-91 integra axles, if you are using a hydro trans (which you should be) then you will use 94+ axles....PERIOD</TD></TR></TABLE>
it just depends on what intermediate shaft you use. One has a male end(94+) and the other has a female end (90-93). So if the GSR swap has a male ended half shaft, then you need to get at least a 94+ drivers side axel. thats it.
LwdJdmR
28
May 13, 2007 11:21 AM
blueskiesfade609
Feb 14, 2005 11:11 PM
Integra_Boi
Jun 16, 2003 05:53 PM
shorty-j
May 13, 2003 05:58 PM
lilpistoldude
Jan 24, 2003 10:08 AM
