GSR fully built with a JRSC { advice needed }
Old Nov 5, 2002 | 09:14 PM
RuffGsR's Avatar
Default GSR fully built with a JRSC { advice needed }
I'm here to get an advice,
I got a 94 gsr supercharged, But my motor has alot of miles already,
Is getting close to 200k,,,Still runs fine , But i gotta start thinking about
building it.
My best time is been 13.5, But i wanna be deep in the mid or low 11's.....(is it possible???)
My plans,
-Fully built GsR
-JRSC with 12psi
-NX 75 direct port
-Hondata
Any advice about what stuff i should use to built my motor,
---What pistons, Rods, Sleeves etc,??????? What would work the best with what i want???
Does anybody knows about a good Shop in California to get my Motor Built????????
Thanks ,
Old Nov 5, 2002 | 09:27 PM
Zero2Sixty's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (RuffGsR)
Just sleeve the block do pistons, rods, and the other Bs, Port and polish your head with some over sized valves, springs and retainers.
That should do it.
Old Nov 5, 2002 | 09:31 PM
texan's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (Zero2Sixty)
That should do it.
He's going to have to ditch the blower for mid to low 11's, that blower was not designed for the power level he is looking for. WAY easier to do this with a proper turbo setup.
Old Nov 5, 2002 | 09:55 PM
stupidfast's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (texan)
pistons, rods, 12psi, and 50shot of nitrous.. No problem high 11s. with good driver and slicks..
Old Nov 9, 2002 | 01:43 AM
Zero2Sixty's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (stupidfast69)
Ditch the blower??? That blower can take him into the 11's with no problems at all with nitrious.
Old Nov 9, 2002 | 08:37 AM
EFing8's Avatar
Ditch the blower. get a turbo and be much happier.
Old Nov 9, 2002 | 09:36 AM
Kataku2K3's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (CND_CRX)
Build the motor, then RevHard Stage 2C with a T3/T04E or straight T04 turbo, my friend Kenny has a setup similar to this in his EK... It puts down 505whp but there's still no traction.. On MT 24.5x9x13 it spins third at the track so right now his best is only an 11.80..
Old Nov 10, 2002 | 07:43 PM
NCSTIdriver's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (JDMspecEG6)
whats wrong with you people he asked how to get into the 11's on his supercharger. He didn't say anything about a turbo. Don't get me wrong I'm not hating on turbos or anything but for the amount it would cost to get a turbo kit and build the engine to run 11's, he could easily build the engine and buy a NX kit and hit 11's on slicks.
Old Nov 10, 2002 | 07:54 PM
Kataku2K3's Avatar
Default Re: GSR fully built with a JRSC { advice needed } (NCH22driver)
Nothing wrong with superchargers.. Just it's easier to hit 11's with a turbo... The traction sucks with a supercharger and there isn't as much top end power.
Old Nov 10, 2002 | 08:06 PM
RuffGsR's Avatar
Actually, This is what i meant.
I want to keep the Supercharger, But I just wanted to find out if it was possible to break into the 11's with the set up that i have in mind.
>But, Anyways Thanks alot for all the good Feedback.
[Modified by RuffGsR, 5:08 AM 11/11/2002]
[Modified by RuffGsR, 5:10 AM 11/11/2002]
slow91crx
Dec 15, 2005 05:07 AM
SHhh__VTEC
Mar 9, 2005 09:05 PM
RuffGsR
Feb 28, 2004 02:44 PM
Undrgrndhaqer
Aug 31, 2003 06:28 PM
