head milling question?
Old Nov 10, 2002 | 03:59 PM
lazyguy's Avatar
Default head milling question?
i have a gsr and i plan to build my head now and save up money to go all out on my block
my question is: if i run a spoon head gasket which raises the compression .3 and i mill the head 10 thous. which should raise comp. about .3, then my cams will actually be retarded with the gears at 0,0 right?
so how much would i have to move them to bring them to the real 0,0 ?
thanks
Old Nov 10, 2002 | 05:39 PM
lazyguy's Avatar
Default Re: head milling question? (lazyguy)
someone?
Old Nov 10, 2002 | 06:56 PM
IN VTEC's Avatar
Don't mill the head if you don't need to.
And, the only way to accurately set the cams to 0,0 is to degree the cams.
Old Nov 10, 2002 | 07:42 PM
chevyalltheway's Avatar
Milling your head shouldn't change the degree of your cams.
Old Nov 10, 2002 | 08:05 PM
Kataku2K3's Avatar
Default Re: head milling question? (chevyalltheway)
Milling the head will set the cams off from the bottom end... for every .012" milled you generally loose 1 degree.
Old Nov 10, 2002 | 08:15 PM
lazyguy's Avatar
Default Re: head milling question? (IN VTEC)
actually the head milling will help me for now with the setup ill be running and when the block is finished ill make sure to compensate for the milled head as to avoid detonation
SR20S13
Feb 23, 2010 06:27 PM
u_tal
Dec 31, 2009 11:23 AM
H22CL
Apr 27, 2004 03:19 PM
