gsr cams in b16a2????
Old Apr 22, 2004 | 06:30 AM
00JDMcivicSI's Avatar
Default gsr cams in b16a2????
i was wonderin if you can put gsr cams in a b16a2 without messin anything up and with stock internals? and if you can, is it worth it? what will be the positive side of it and the negative side?
Old Apr 27, 2004 | 12:12 AM
Katman's Avatar
Default Re: gsr cams in b16a2???? (00JDMcivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00JDMcivicSI &raquo;</TD></TR><TR><TD CLASS="quote">i was wonderin if you can put gsr cams in a b16a2 without messin anything up and with stock internals? and if you can, is it worth it? what will be the positive side of it and the negative side?</TD></TR></TABLE>
yes you can do this and nothing needs to be changed besides the camshafts.
benefits gained will be a slight increase in torque, you probably won't feel it though.
Old Apr 27, 2004 | 10:12 AM
Clutchmasta55
Guest
Posts: n/a
Yes, you can use gsr cams in your b16a2 and no it wont mess anything up.
Any b-series cams will work in your ride without any modifications and to answer your other question "is it worth it? In my opinion "no" expect the gain to be very mininal. The cam lobes on your b16 are actually bigger than the Gsr's.
Hope that helps a bit
Old Apr 27, 2004 | 01:33 PM
VtecDeMoN's Avatar
Default Re: gsr cams in b16a2???? (Clutchmasta55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clutchmasta55 &raquo;</TD></TR><TR><TD CLASS="quote">
Jesus, katman I didn't know it echoed in here.
Brian
Old Apr 28, 2004 | 07:00 PM
Clutchmasta55
Guest
Posts: n/a
Default Re: gsr cams in b16a2???? (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN &raquo;</TD></TR><TR><TD CLASS="quote">
Brian</TD></TR></TABLE>
Old Jun 14, 2004 | 02:28 PM
tencan's Avatar
Cam lobes are bigger. the lift is higher on the gsr and the duration is longer, how can the b16 be bigger..
Old Jun 14, 2004 | 02:57 PM
CA6VTEC's Avatar
<FONT COLOR="royalblue"> I wouldn't do that.. GS-R non-vtec lobes reach their peak @ 4400rpm, then the xover takes place. B16 cams reach their peak @ 5600, then the xover takes place. So from 4400rpm to 5600, you will lose some power, unless you retard the xover point on ur ECU. </FONT>
Old Jun 14, 2004 | 03:14 PM
mattssi's Avatar
Default Re: gsr cams in b16a2???? (tencan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tencan &raquo;</TD></TR><TR><TD CLASS="quote">
Cam lobes are bigger. the lift is higher on the gsr and the duration is longer, how can the b16 be bigger.. </TD></TR></TABLE>
I have three differn't kinds on b series cams in my shop right now. 1st gen b16, 94-97 gsr, and b16a2 out of a 99-00 si. Upon visual inspection the b16a2 have more lift than the other two, But the Gsr's appear to have more duration. The 1st gen b16 ones seem to be really close to the gsr in lift.
panda_eh2
Apr 18, 2008 12:17 PM
Project_EK
Sep 25, 2006 08:27 PM
turbo*s2k
Sep 15, 2005 01:26 PM
00JDMcivicSI
Jun 27, 2004 05:22 AM
