Grounding ignition wire boots with test light. Bad?
Old Apr 14, 2011 | 06:11 AM
wc4ohio's Avatar
Default Grounding ignition wire boots with test light. Bad?
When diagnosing a dead cylinder, I usually probe the boots of the ignition wires with a test light. I stick the sharp end of the test light probe straight thru the rubber and kill the cylinder temporarily to see if there's any current thru the wire without having to unplug it. It also shows if there's no difference in engine behavior that I have probably found the misfire. When I pull the probe away, the hole closes itself (it's so small to begin with anyways)
Recently, I was told this is a bad way to test. Is it? If so, why? It's not like I'm killing the live cylinders for long periods.
Old Apr 14, 2011 | 07:37 AM
frankenghia's Avatar
Default Re: Grounding ignition wire boots with test light. Bad?
One reason is you should never poke a hole no matter how small into a spark plug wire. I have seen the smallest of holes in a plug wire arc.
Old Apr 14, 2011 | 07:50 AM
wc4ohio's Avatar
I usually plop some liquid electrical tape over the hole when I'm done. The guy giving me crap was spouting some junk about ruining the ignition coil. I've done it a lot and never had a problem; but I'm not an expert.
Old Apr 14, 2011 | 10:20 AM
I have heard of the coil going out on hondas due to this. I haven't ever had it happen to me but have seen and heard about it many times.
Old Apr 16, 2011 | 06:45 PM
uberEFtuner's Avatar
Why poke a hole in something perfectly good? It just as easy to pull off the plug wire?
Old Apr 16, 2011 | 07:04 PM
Chiovnidca's Avatar
It shouldn't hurt the coil, but it's not going to do the wires any good.
S.A. civic
10
Aug 18, 2013 01:19 AM
cody1234
Nov 30, 2012 05:34 AM
DJ_SaNdOz
10
Jan 21, 2005 05:38 PM
