grinding when stepping on clutch pedal
Old Jun 15, 2006 | 08:11 PM
BoOsTiN Dc2's Avatar
Default grinding when stepping on clutch pedal
I'm getting a grinding noise when i step on my clutch pedal almost all the way. Everything was fine... i was driving and all of a sudden i was barely getting into gear and when i stepped on my clutch pedal it started grinding. What could be the problem? I'm running a gsr tranny with a tilton twin disk clutch.
Old Jun 15, 2006 | 08:45 PM
postman's Avatar
Default Re: grinding when stepping on clutch pedal (BoOsTiN Dc2)
maybe, https://honda-tech.com/zerothread?id=1657228
Old Jun 15, 2006 | 08:48 PM
Default Re: grinding when stepping on clutch pedal (postman)
so you think its the throwout bearing? i dont have the symptom of the ones listed in your post
Old Jun 16, 2006 | 07:05 AM
kordenbrock motorsports's Avatar
twin discs have floating discs...are you sure youre not hearing them float? it also may be the disc hitting the flywheel bolts...check and make sure you have a clutch pedal stop. i had some of the same issues
brett
Old Jun 16, 2006 | 04:45 PM
Default Re: (kordenbrock motorsports)
i know how a twin disk clutch sound like... this was what happened
https://honda-tech.com/zerothread?id=1661698
Old Jun 17, 2006 | 10:27 PM
sorry then, just putting some obvious stuff out there. sometimes things like this are overlooked due to their blateness...hope you figure something out.
brett
s_vares
Acura TL, RL & ZDX
Jul 16, 2011 04:40 AM
llozll
Dec 26, 2006 09:54 AM
Jmumblez2001
Aug 8, 2006 12:05 PM
jdmcivicferio
Jul 9, 2004 02:15 PM
Que
Jan 17, 2002 10:37 PM
