Grinding in 5th
Old Jun 3, 2002 | 03:02 PM
subliminizm's Avatar
Default Grinding in 5th
Sometimes when I shift into 5th gear I get a grinding sound. From your guys' posts it seems to be that the synchros are messed up. I don't have a waranty on my GSR, where do you guys suggest getting it fixed: Acura, Pep Boys, local Tranny shop? How much shoukd I expect to pay?
Thanks
[Modified by subliminizm, 12:02 AM 6/4/2002]
Old Jun 3, 2002 | 05:13 PM
Default Re: Grinding in 5th (subliminizm)
come on guys...Some help please!
Old Jun 3, 2002 | 05:25 PM
slomofo's Avatar
GDD Member
Go to a local shop. Pep boys takes forever and rips you off, acura will rip you a new *******. Before I knew anything about cars, I took my integra to Acura to have the trans fluid changed for $90.
Old Jun 3, 2002 | 09:47 PM
Rocket's Avatar
Default Re: Grinding in 5th (slomofo)
You might just be low in tranny fluid. Check that.
Old Jun 4, 2002 | 06:21 AM
Default Re: Grinding in 5th (Rocket)
Cool, yeah i should check my tranny fluid first. Thanks
Old Jun 4, 2002 | 06:28 AM
John's Avatar
New User
Check it, consider that it might need to be changed. In the meantime, double-clutch 5th gear so you won't grind it anymore (push clutch down put it in neutral, then repress the clutch and put it in 5th).
Old Jun 4, 2002 | 06:41 AM
Default Re: Grinding in 5th (DunReit)
So clutch down, put in neutral, then let go and hit the clutch again, and then put it in fifth, and then let go of clutch. Is that right?
Old Jun 4, 2002 | 06:45 AM
John's Avatar
New User
Correct.
Old Jun 4, 2002 | 07:56 AM
polarmashli's Avatar
I just starting having the problem too!... I just installed a AEM intake and I was messing around with it... ie driving like an a$$.... misshifted into 5th...and now its grinding everytime I go into it ... Now i have to take out the intake...put stock in.... hope they dont notice the direct line from the valve cover to the oem intake.... and hope they fix it....double clutching stops it completly....
intake rocks btw... worth the money...
Old Jun 4, 2002 | 08:42 AM
TypeSH's Avatar
Default Re: Grinding in 5th (polarmashli)
if a car is low on or using bad tranny fluid, is 5th gear the first one that grinds to show it? or would other gears shwo some trouble shifting into if the fluid is bad?
Old Jun 4, 2002 | 08:59 AM
Rocket's Avatar
Default Re: Grinding in 5th (TypeSH)
5th gear is physically the smallest gears and picks up less oil than any other gear so it's the first one to act up when the tranny fluid gets low.
Old Jun 4, 2002 | 09:14 AM
John's Avatar
New User
I wonder if I should switch back to Honda MTL since I've been having problems with the Redline MTL...
Old Jun 4, 2002 | 11:22 AM
stockegsix's Avatar
i have a Gsr tanny and i grind on 5th too, how do you check the tranny fluid?
Old Jun 4, 2002 | 11:24 AM
i just got the trans fluid changed... i dont think it was honda...actually..it was some syntechic stuff.... ...
this sucks
Old Jun 4, 2002 | 11:30 AM
John's Avatar
New User
When I first changed over to Redline Syn MTL in January, 5th grinded for about 4-6 weeks (why, I don't know). Then it went away, and returned with a vengence about 2 weeks ago. That's why I'm thinking of switching back to Honda MTL.
[Modified by DunReit, 3:30 PM 6/4/2002]
DC5Danny
Jan 21, 2008 08:36 AM
BlackLudeSR
Jun 21, 2007 01:50 PM
be18see1
Aug 20, 2006 11:05 AM
WingDC2R
Dec 11, 2005 08:21 PM
DubyaAye
Sep 22, 2004 06:23 PM
