greasing ball joints on the car
Old Mar 26, 2003 | 08:27 AM
CXHatchback's Avatar
Default greasing ball joints on the car
Is this possible? And where would I be able to access it? I think my lower ones and tie rod ends need it but don't know where to put it. I just bought a grease gun but there's no fitting or anything that would help me....
Old Mar 26, 2003 | 11:34 AM
Aron Parsons's Avatar
Default Re: greasing ball joints on the car (CXHatchback)
Unless your boots are cracked and leaking grease, the joints do not need to be greased. If they are cracked, get some Energy Suspension replacements ($3). Then pack the new ones with moly grease.
Old Mar 26, 2003 | 06:10 PM
Default Re: greasing ball joints on the car (Aron Parsons)
well Ijust replaced most of my ball joints, but they're making a knocking sound like they're bad, I was thinking maybe they didn't come pregreased, but I don't konw. I was hopin I could add some but I don't know how.
Old Mar 27, 2003 | 03:51 PM
PnX-R's Avatar
For some weird reason, I thought Hondas didn't have greasable Ball Joints.. But hey, I could be wrong.. Someone let me know..
Old Mar 27, 2003 | 03:52 PM
Default Re: greasing ball joints on the car (PnX-R)
I don't think I can grease them on the car, I think I have to dissasemble them, which is what I fear. I thought they came pregresed, but they're making a cracking/knocking kind of sound when I turn and accelerate from a stop.
Old Mar 27, 2003 | 04:21 PM
PnX-R's Avatar
I don't believe Ball Joints come pre-greased. At least not the ones I've done.. But then again, it wasn't a Honda either..
Old Mar 27, 2003 | 04:49 PM
senpai's Avatar
Yep. Check the boots. If you installed new ball joints then they already have a boot and are therefore pre-greased.
<---- Installed own ball joint with hand tools. Back hurt next day.
Old Mar 27, 2003 | 05:41 PM
ChiBoy's Avatar
The EG ball joints I installed came pre-greased from Honda.
If the front end is making strange sounds after you finished, then you may have done something wrong when you put it back together. I would get down there and double check everything.
Old Mar 27, 2003 | 05:59 PM
Default Re: greasing ball joints on the car (ChiBoy)
That's def. what it's doing. Whenever I make slow turns or accelerate it cracks and knocks. I'm waiting for something to break. It just started happening once I put stock suspension back on, so I'm thinking it has something to do with that
Old Mar 27, 2003 | 08:24 PM
keebler65's Avatar
when i did tie rods on my rex, they didnt come greased. they came with the little nipples that you screw into each one, then attach a grease gun and pump it in. after i did this, my non-power steering wheel was MUCH easier to turn
Old Mar 27, 2003 | 09:11 PM
CRX7's Avatar
Default Re: greasing ball joints on the car (keebler65)
did my ball joints and tie rods a few months ago, none of the parts came pre-greased. Yes you need to take it apart again, and you need to go back to the autoparts store and get a needle attachment for your grease gun, you stick the needle between the post and the boot on the joint and squirt grease in.
However, the fact that you didn't grease the joint should cause it to knock and make noises, you left something loose. So take it apart again, grease your joints and put it together again.
rjmq06
May 23, 2015 08:00 AM
DelSolMarine
11
Apr 14, 2006 08:11 PM
chrisb
Nov 28, 2005 02:38 PM
ablack934doorcivic
Apr 16, 2005 09:41 PM
Space Boy
Suspension & Brakes
Feb 24, 2005 01:46 PM
