got one of my nutz Stuck!...
Old Feb 13, 2004 | 08:11 AM
  #26
Burke's Avatar
Banned
Default Re: (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
i just got these and i cant weight to use them. i hear they work AWESOME!!!!
Old Feb 13, 2004 | 11:23 AM
  #27
OTT's Avatar
OTT
Default Re: got one of my nutz Stuck!... (NAPA182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPA182 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL ha ha to funny </TD></TR></TABLE>
ahaa. Nice one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">
i just got these and i cant weight to use them. i hear they work AWESOME!!!!</TD></TR></TABLE>
Man they dont sell these anywhere; i spent this moring finishing Hammeright'ing my Cradle and control arms for my lude then spent the afternoon looking around hardware stores, you gotta drop me a link to the harbor freight website man!
Old Feb 13, 2004 | 12:13 PM
  #28
LudeyKrus's Avatar
The only place i've seen those things are at Sears; they are Bolt-Offs. They work great for stripped nuts and bolts, but probably won't help here b/c the nut is rusted SOLID.
Plus they're a bit fatter than a normal socket, and he said he could barely get the socket onto the nut.
Old Feb 13, 2004 | 12:40 PM
  #29
OTT's Avatar
OTT
Im going to try with a hack-saw blade in a special handle, Although I wont be able to move it far each stroke; elbow-grease along with persistance always pays-off. So Tomorrow morning I should have it off and go get a new stud from honda.
Then i can drop the old cradle rear section, strip it down and put all the good parts onto my new cradle/PAS assembly.
Then itll be time to:
*Raise new rear section of cradle
*Swapout front section
*connect everything up
*Drain the tranny and fit intermediate shaft
*Fill tranny with silktran 5
*Put my new suspension on
*Borrow a low-loader truck and go to Honda for a 4ws Alignment!
then flog the Peugeot run-around and spend the money on the Prelude!
What a plan.
Old Feb 13, 2004 | 08:28 PM
  #30
snoochtodanooch's Avatar
Default Re: (tegmech)
pneumatic hammer or chizzle, will cut the head off clean in a matter of seconds. if you need to save a stud just split the nut and then take it off. But i would also use the easy offs first, would be much easier and save lots of time with grinding and damage. I use easy outs all the time at my work, and they are life savers at times, and ****** in others.
Old Feb 14, 2004 | 06:47 AM
  #31
BigMoose's Avatar
Default Re: (snoochtodanooch)
you said you have my favorite tool, the heat wrench (oxy-acetylene). Heat the nut red and hammer on a slightly smaller socket, mix and match english/metric to get the right fit.
Then rachet fast. It will come right off, once the heat of expansion cracks it loose. ... Believe me, us "rust belt" guys, know how to get rusted stuff apart. The heat wrench, don't leave home without it!
Old Feb 16, 2004 | 03:00 PM
  #32
Quick 200k Mile Motor's Avatar
Default Re: (BigMoose)
heat works
Old Feb 19, 2004 | 05:45 PM
  #33
OTT's Avatar
OTT
Couldnt do itwth the torc as I'd already grinded too much off of the rounded nut on one side to get a smaller socket on and no room to hammer, Ended up dropping the whole system but found somthing really odd that I didnt take notice of, Pics will be up tonght probly
Old Feb 19, 2004 | 06:07 PM
  #34
InjectedPerformance's Avatar
We sell parts.
Default Re: (OTT)
Dude you could of had it off by now. Cut the dam bolt with a saw-zaw. It will take like 5 min.
Old Feb 19, 2004 | 06:47 PM
  #35
OTT's Avatar
OTT
i just took the whole sys down, I will cut it off wen I need to but Ill be changing to a full aftermarket system soon-enough!
dorkjoey
Apr 11, 2008 05:28 PM
HCJDM1
Feb 2, 2007 06:09 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
RCautoworks
Welding / Fabrication
19
Feb 1, 2006 10:59 PM
StrangerWitCandy
Sep 3, 2005 08:37 AM
