good compression, bad leak down!! what does it mean??
Old Oct 22, 2003 | 08:10 PM
crx1856's Avatar
Default good compression, bad leak down!! what does it mean??
i went to dsr today to get tuned with poor results. after doing a leak down test, i had a 3% 12% 12% and a 7%. but when i do a compression test, i get high 190's all across. this is on a 84mm 9-5-1 motor. what does it mean when you have good comp numbers with poor leak down tests. my tuner said it might be the rings still trying to seat. the motor has 650 miles on it right now. the highest dyno run was a 170 whp. this is with a revhard 2c kit. anyone have any awnsers???
Old Oct 22, 2003 | 08:55 PM
HONDADNA's Avatar
Default Re: good compression, bad leak down!! what does it mean?? (crx1856)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1856 &raquo;</TD></TR><TR><TD CLASS="quote">i went to dsr today to get tuned with poor results. after doing a leak down test, i had a 3% 12% 12% and a 7%. but when i do a compression test, i get high 190's all across. this is on a 84mm 9-5-1 motor. what does it mean when you have good comp numbers with poor leak down tests. my tuner said it might be the rings still trying to seat. the motor has 650 miles on it right now. the highest dyno run was a 170 whp. this is with a revhard 2c kit. anyone have any awnsers???
Your leak down results are okay - Your still in breakin your motor. But, it sounds like DSR - HAVE NO CLUE TO WHAT THEY ARE DOING.. I leak down is not accurate for testing piston ring. A leak down is more accurate for testing bend valve.
B18EG6
Jan 29, 2006 02:24 AM
crx1856
Oct 23, 2003 06:46 PM
RedRacerCivic
11
May 22, 2003 10:29 AM
gsr~hatch
Apr 17, 2003 03:19 PM
Zorro
Nov 26, 2001 09:42 AM
