GOOD CAMS FOR MY LS/VTEC
Old Jul 28, 2004 | 06:24 PM
evilk's Avatar
Default GOOD CAMS FOR MY LS/VTEC
WAT R GOOD CAMS FOR MY LS/VTEC.. MY FRIEND SUGGESTED CRANE CAMS SO WAT YA THINK... I'M RUNNIN WIT NITROUS TOO
CURRENT MODS
B18B BLOCK
BLOCC GUARD
POLISH CRANK
EAGLE RODS
JE SRP PISTON 10:5:1
B16 HEAD
KMS DUAL VALVE SPRINGS
TI RETAINERS
VALVES
AEBS MANIFOLD
AEM INTAKE
NOS SINLGE STAGE WET SYSTEM
DC 421 HEADERS
APEXI N1 EXHUAST
FULL MSD SETUP
http://WWW.TEAMKINETIC.COM
Old Jul 28, 2004 | 06:54 PM
Icey112's Avatar
Default Re: GOOD CAMS FOR MY LS/VTEC (evilk)
crane hell no any thing but them ctr or skunk2 stage 1 are good for nitrous.
im running skunk2 stage 1 but i have not had a chance to spary it my ******* tranny is fucked up. But it pulled hard with them in it before my tranny started ******* .
Old Jul 29, 2004 | 09:23 AM
evilk's Avatar
Default Re: GOOD CAMS FOR MY LS/VTEC (Icey112)
thats wats i was thinkin to skunk2 stage 2 doe...so wat kind of tranny u running i'm runnin tha gsr work real good
Old Jul 29, 2004 | 11:13 AM
Icey112's Avatar
skunk2 stage 2 cams are great cams for n/a but to spary nitrous on i don't no the lobs are so big for the nitrous.
my motor is a fully bulit gsr with a b16a2 tranny that is makeing me go crazy.
Old Jul 29, 2004 | 11:42 AM
Sack Master's Avatar
The big differece between nitrous/turbo/supercharger cams over all motor cams is not so much the lobe size but is more so the lobe seperation. The only problem with nirtous on a big cam that would really be an issue is intake reversion which would only really happen on a very large shot of nitrous and a head that doesn't flow well. Granted cams that are designed primarily for nitrous are a little better performance wise than one that is not. But with skunk2 stage 2 cams it really is tuning for nitrous. That is the tight thing about having DOHC is you can taylor your lobe seperation to your needs. Overlap is not very useful in a nitrous application.
Old Jul 29, 2004 | 12:07 PM
LudeyKrus's Avatar
Short answer:
Nitrous does not affect what cam you select. You should select the cam that best fits your motor when it is not on the bottle.
Nitrous does not behave like boost, therefore you don't need a special cam for it.
Old Jul 29, 2004 | 03:04 PM
evilk's Avatar
Default Re: GOOD CAMS FOR MY LS/VTEC (Sack Master)
so what cams you think i should go wit i'm only running 100 shot
Old Jul 29, 2004 | 03:05 PM
evilk's Avatar
does nitrous cams lagg consis of tha all motor cams
Old Jul 29, 2004 | 05:22 PM
TEZTnTUNE's Avatar
lots of nitrous profiles that ive seen emphasize lift and duration on the ex cam. improving the airflow out of the engine. a good set of nitrous cams are only as good as your exhaust system. i would go for a combination of the two. one that augment the other.
Old Jul 29, 2004 | 07:03 PM
evilk's Avatar
Default Re: GOOD CAMS FOR MY LS/VTEC (drp_shp_tech)
yea i think thats would be the best way too.thanx
blackcrx16
11
Dec 18, 2007 07:39 AM
dwn-shift
Dec 5, 2002 11:34 AM
Midwestrider
Mar 21, 2002 11:55 PM
