General Question About Main Bearings - engine problems, help!!!
Old Apr 8, 2008 | 06:40 PM
mikemjohnson's Avatar
Default General Question About Main Bearings - engine problems, help!!!
i searched.
car has been making sounds (1998 base prelude h22a4), dealer diagnosed it as having noisy main bearings and that ill need a new engine soon. so my question is what can i do? can i replace just the block, or just certain parts of the engine to avoid having to buy a new H22? if not the block, what is the least i can do to fix this - i know/been told that you cant rebuild the main bearings or anything to that nature. so help me out, in a rough spot, car still driving but its gonna be toast soon
ALSO
flashing oil light, low oil pressure (i figured) according to the dealer. what steps can i take to try to fix this before having to get a new oil pump put in? Thanks
Old Apr 8, 2008 | 06:50 PM
egb16pg's Avatar
Default Re: General Question About Main Bearings - engine problems, help!!! (mikemjohnson)
The flashing oil light can be due to your excessive bearing clearances.
However, you can just do a rebuild, get the crank measured, and use undersize bearings which will be cheaper than buying a new motor, but if your main's are about to go out then most likely your motor is weared down. So your best bet i would say is swap the motor as the tech at the dealer said.
Old Apr 8, 2008 | 07:04 PM
yeah i figured id just get a new one but the dealer can wipe my *** with their hands if they think im gonna pay 3533
ill see what i can do to get one locally and installed by a mechanic. ROUGHLY how much am i looking at for a DECENT mileage h22, doesnt have to be very low mileage
Old Apr 13, 2008 | 12:54 PM
g2daturbo's Avatar
Default Re: (mikemjohnson)
usually can find a nice engine for 1000 or under and find someone local to do it for $500 or less.. Looking at about 1500 installed for a nice engine maybe find a better deal...
LudemanDan
Mar 26, 2008 07:40 PM
burnitup
Aug 23, 2007 09:19 PM
blkrex
Oct 4, 2006 09:23 AM
TeAm IllUsIonZ978
Oct 31, 2002 05:52 PM
