Gauges recommended for Nitrous usage?
Old Feb 7, 2002 | 03:24 PM
Midwestrider's Avatar
Default Gauges recommended for Nitrous usage?
I am looking for the most needed gauges for a nitrous setup (with the execption of the nitrous gauge).
I have a wet kit. I have the norm.. I/H/E, fuel rail(aem), fpr(aem), and fuel gauge.
The motor is a sohc, D16. I will be soon swap in a DOHC.
From doing some searching on the site here, the 3 gauges for a all motor are:
oil press, oil temp, and water press,
I have space for 5 gauges, (2) in dash bezel, and (3) on the pillar.
I was looking at a greddy a/f, egt, water temp, oil press, oil temp.
Another question has anyone be able to dremel a autometer (triple) 2-1/16 pod to fit a 60mm gauge?
Reason I ask cause I would like to install the greddy a/f (only comes in 60mm) and egt (60mm) in the pillar pod and put a 52mm gauge in the last opening.
And then put (2) 52mm in the bezel.
What 5 gauges would be best suited for what I have mentioned?
thx
Eric
Old Feb 7, 2002 | 04:21 PM
CanadaCivicSIR's Avatar
New User
Default Re: Gauges recommended for Nitrous usage? (Midwestrider)
I have in my car: A/F guage, Oil Pressure, Fuel Pressure, EGT and Nitrous Pressure.
Old Feb 7, 2002 | 08:43 PM
Default Re: Gauges recommended for Nitrous usage? (CanadaCivicSIR)
You wouldn't happen to have any pics of your gauges installed would you?
What model gauges are you using?
Thanks
Old Feb 9, 2002 | 05:29 PM
New User
No pics right now,scanner busted!!!!
I have AutoMeter guages Phantom series(I like the white faces)
EGT, Nitrous pressure and Fuel Pressure on A pillar in triple guage mount. Oil pressure and A/F guage in instrument cluster.
Old Feb 9, 2002 | 08:53 PM
Thx man
Anyone else??
DaveSi677
30
Mar 16, 2015 08:18 AM
iH8RICERZ
Nov 25, 2002 03:02 PM
Midwestrider
Feb 11, 2002 03:40 PM
Midwestrider
Feb 9, 2002 11:04 AM
IntegraR0064
Jul 2, 2001 09:08 PM
