Gauges recommened for Nitrous usage
Old Feb 7, 2002 | 03:06 PM
Midwestrider's Avatar
Default Gauges recommened for Nitrous usage
I am looking for the most needed gauges for a nitrous setup (with the execption of the nitrous gauge).
I have a wet kit. I have the norm.. I/H/E, fuel rail(aem), fpr(aem), and fuel gauge.
The motor is a sohc, D16. I will be soon swap in a DOHC.
From doing some searching on the site here, the 3 gauges for a all motor are:
oil press, oil temp, and water press,
I have space for 5 gauges, (2) in dash bezel, and (3) on the pillar.
I was looking at a greddy a/f, egt, water temp, oil press, oil temp.
Another question has anyone be able to dremel a autometer (triple) 2-1/16 pod to fit a 60mm gauge?
Reason I ask cause I would like to install the greddy a/f (only comes in 60mm) and egt (60mm) in the pillar pod and put a 52mm gauge in the last opening.
And then put (2) 52mm in the bezel.
What 5 gauges would be best suited for what I have mentioned?
thx
Eric
Old Feb 7, 2002 | 04:22 PM
KoRE's Avatar
Default Re: Gauges recommened for Nitrous usage (Midwestrider)
2 i can recomend are A/F ratio(you already have), and a fuel pressure.
I would say a nitrous pressure gauge but you already know that
Old Feb 7, 2002 | 08:47 PM
Anyone else?
I have searched here in the FI section but most ppl are running turbo's, anyone else with nitrous care to share some input?
Old Feb 9, 2002 | 11:04 AM
ttt, anyone???
3 plus 1
Mar 20, 2004 11:08 PM
RCautoworks
30
May 9, 2003 06:42 PM
Midwestrider
Feb 11, 2002 03:40 PM
Midwestrider
Feb 9, 2002 08:53 PM
IntegraR0064
Jul 2, 2001 09:08 PM
