gauge cluster temp gauge?
Old Mar 25, 2009 | 02:33 PM
bstadictd's Avatar
Icon2 gauge cluster temp gauge?
temp gauge goes right to "H" right on start up and the gauge cluster doesnt light up. i have been trying to locate all of the grounds hoping to find one disconnected.I have also replaced the temp sensor and have found no blown fuses and no blown bulbs in the cluster. Curently out of ideas. help needed
Old Mar 25, 2009 | 05:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: gauge cluster temp gauge?
MM&Y of car??? 94
Old Mar 25, 2009 | 08:56 PM
bstadictd's Avatar
92 civic si
Old Mar 26, 2009 | 05:00 AM
fcm's Avatar
fcm
Old Fart
Pull cluster and meter the red/black lead, [power for dash lights and should be 12V+ when park/head lights are on] meter red lead, [ground for dash lights and should be ground, "veritable" as you adjust "Dash Lights Brightness Controller"].
For temp gauge test for continuity to ground on temp lead, should be a yellow/green, should be no more then about 140 ohms, [cold engine] 50-30 ohms when engine at running temp.
Check for continuity on yellow/green between sensor and gauge. 94
Old Mar 26, 2009 | 01:42 PM
bstadictd's Avatar
so far i have tested the temp sensor i got 77 omhs the engine probably wasnt all the way warm didnt drive it just let it run for a few. as i was testing it the omhs slowly went down like i should if it was still getting warmer. so i think that the gauge is probably bad. can the gauge be replaced or do i need a new cluster
Old Mar 27, 2009 | 06:27 AM
fcm's Avatar
fcm
Old Fart
Sorry, not sure just the gauge, on a 92 Civic, can be replaced, I would think so, one way or another. 94
Old Mar 27, 2009 | 07:01 AM
instructor74's Avatar
you can take the gauge cluster appart and replace the gauge with a used one I am not sure if they are avil new. Here is a link for the exploded veiw with parts and price better of gett it used
http://www.hondaautomotiveparts.com/...TER+COMPONENTS
Old Mar 27, 2009 | 10:55 AM
bstadictd's Avatar
thanks for the help. i will be replacing the whole cluster with one from the junk yard and probably the dimmer switch also
Old Mar 27, 2009 | 11:08 AM
fcm's Avatar
fcm
Old Fart
http://shop.ebay.com/items/_W0QQ_nkw...romZR40QQ_mdoZ 94
dglassmyer
Apr 27, 2010 08:14 PM
rollinonblades
Oct 14, 2008 02:49 AM
qboi85
Feb 22, 2006 06:42 AM
Mrfeee1
Oct 7, 2004 08:40 AM
rexnation
Jul 14, 2004 03:08 PM
