Help with gauge cluster
Old Nov 15, 2005 | 06:11 PM
Racersky's Avatar
Default Help with gauge cluster
Can anyone help me with my gauge cluster? It was working fine yesterday and all of a sudden when I turn the lights on the entire gauge cluster doesn't come on. Is it because of a fuse?
Old Nov 15, 2005 | 09:10 PM
romoracing's Avatar
Default Re: Help with gauge cluster (Racersky)
check the fuse. your also going to need to tell us more about it.
Old Nov 16, 2005 | 07:16 AM
Racersky's Avatar
Default Re: Help with gauge cluster (romoracing)
what else do you need to know?
Old Nov 16, 2005 | 08:09 AM
B18C_EJ8's Avatar
What do you mean by "cluster"? Are you talking about your factory instrument panel or an aftermarket gauge mount?
I'm assuming you mean the factory panel... You say that the entire thing doesn't light up, so does that mean that some of it is illuminated? If so, you'll need to pull the cluster and change the bulbs on the back side of the unit. Easy. Quarter turn and the bulb pops out.
Old Nov 16, 2005 | 11:30 AM
Racersky's Avatar
Default Re: (B18C_EJ8)
I'll try to take a picture of it and posted up. Yest only some of it light up. Like for example the Odometer lights up.
Old Nov 16, 2005 | 11:45 AM
B18C_EJ8's Avatar
Like I said earlier:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You say that the entire thing doesn't light up, so does that mean that some of it is illuminated? If so, you'll need to pull the cluster and change the bulbs on the back side of the unit. Easy. Quarter turn and the bulb pops out. </TD></TR></TABLE>
Sounds like you've got blown bulbs.
project ak
Jul 28, 2006 02:33 AM
sirpsychosexy1
Jul 8, 2005 11:28 AM
Slow_Boy
Aug 24, 2004 12:45 PM
rexnation
Jul 14, 2004 03:08 PM
