gas pressure line
You can as a temp fix yes. Be sure to use a hose that's rated for at least 60 psi to be on the safe side. And use good strong clamps. Remember this is a temp fix it won't last forever
it would also be wise to use fuel hose. and to further emphasize the temporary use.. temporary as in you still need to drive to and from work while you wait for the correct part to arrive on order.
a fuel leak is a fire waiting to happen. a burnt up car is a terrible thing. a burnt up driver and passengers is worse.
Louie_EM1
12
Feb 27, 2005 11:16 AM
