Gas in oil?
Old Apr 22, 2007 | 05:36 PM
aklano's Avatar
Default Gas in oil?
Just checked my oil and it noticeably smelled like fuel. Level was possibly up a tiny bit from the last time I checked a couple days ago, not sure. Anyway I heard it could be fuel pump of an injector leak. Whats the best way to diagnose this problem? If I have to pull the injectors or pump how do I tell the problem when I see it? Thanks in advance anyone who helps .
Old Apr 22, 2007 | 05:49 PM
NJIN BUILDR's Avatar
Default Re: Gas in oil? (aklano)
If it's a stock system you should be getting a CEL.If it's been chipped then any thing's possible.You can pull spark plugs and see if one is different than he others.This will tell you if one injector is bad.A fuel pump rarely gets richer it usually gets leaner.
Old Apr 22, 2007 | 05:56 PM
sitinthehall's Avatar
Could be from blow by. Your rings might be starting to go bad. How many miles are on your motor?
Edit: Sorry I said nothing to worry about... Not what I meant.
Modified by sitinthehall at 5:12 AM 4/23/2007
Old Apr 22, 2007 | 05:59 PM
tbuck23's Avatar
Default Re: Gas in oil? (sitinthehall)
i have the same problem am getting gas in my oil two we think two of my injectors are bad will that fix the problem
Old Apr 22, 2007 | 06:12 PM
Default Re: Gas in oil? (tbuck23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tbuck23 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem am getting gas in my oil two we think two of my injectors are bad will that fix the problem</TD></TR></TABLE>
Yes.If it has bad injectors and you replace them you we will be back in business.You should see a difference it the spark plug if the injectors are bad.
Old Apr 22, 2007 | 08:07 PM
arc_55's Avatar
Fuel in your oil is a dangerous thing! Fuel in the oil breaks down the oil looses its properties and turns thin. The reason for this is exessive engine blow by. Check for pcv operation and possibly replace and also do a dry and wet compression test to confirm it is the rings. Also check injectors to see if one is not intermittently sticking... as one user said pull the plugs and see if you can narrow it down to a paticular cylinder.
Old Apr 22, 2007 | 09:37 PM
aklano's Avatar
thanks, pcv?
deerman2701
23
Oct 22, 2012 11:50 PM
backstrap1
Honda S2000
Mar 22, 2010 06:32 PM
mooneybeams
Mar 16, 2007 10:20 AM
aZnInTgRa
Sep 17, 2004 07:20 AM
siis2fast
Jun 3, 2004 10:12 PM
