GAS instead of GASOLINE
Old Mar 22, 2005 | 09:23 AM
B18C R Spec's Avatar
Default GAS instead of GASOLINE
Hello to all my honda-tech members. I just came back from my vacation in D.R. and I saw something that was pretty dangerous but interesting that I wanted to share with you guys.
In D.R. cars are adapted to use GAS instead of GASOLINE. They do this to minimize the cost of fuel because gasoline is to expensive for them.
Here are some pics that I took for you guys to see.
This pic shows how the guy pluging the gas line to fill up the tank (located on the truck).
This pic shows the tank on the truck and the way is mounted.
This pic shows what we would call the "pump"
This pic shows the system (converter) that injects or somewhat releases the gas inside the manifold. (circled in red)
Old Mar 22, 2005 | 09:28 AM
DutchITR1689's Avatar
Default Re: GAS instead of GASOLINE (B18C R Spec)
Nothing new here in Europe. A lot of cars run on gas (LPG) here. It's not so dangerous anymore.....
Old Mar 22, 2005 | 09:36 AM
dFreezy's Avatar
Default Re: GAS instead of GASOLINE (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">Nothing new here in Europe. A lot of cars run on gas (LPG) here. It's not so dangerous anymore.....</TD></TR></TABLE>something about that set-up B18CRSpec shows is still pretty scary to me
Old Mar 22, 2005 | 09:52 AM
Black R's Avatar
25 Year Member
propane?
A lot of public transportation had adopted this here in ATL.
There are lots of busses and the like that use it..... Burns clean.
Old Mar 22, 2005 | 09:58 AM
JDMTYPER's Avatar
Default Re: GAS instead of GASOLINE (Black R)
All of our work Vehicles run on Propane as well as one of my personal vehicles.
Old Mar 22, 2005 | 10:09 AM
uzabatty's Avatar
Default Re: GAS instead of GASOLINE (JDMTYPER)
looks dangerous, not that gasoline can't be
Old Mar 22, 2005 | 12:58 PM
Big Phat R's Avatar
Could be CNG too (compressed natural gas)
Taxis here run on that
Old Mar 22, 2005 | 01:06 PM
Aquafina's Avatar
Default Re: GAS instead of GASOLINE (Big Phat R)
I was thinking about buying a 92ish Civic and doing that to it, but NG prices change so much and are expensive during the winter. The octane would be crazy though....16:1 on pump, aahahahahahahahahah
hahahahahahahahahahaha
hahahahahahahahaha
STFU Blue Bear.
Old Mar 22, 2005 | 01:09 PM
AnToNy's Avatar
Default Re: GAS instead of GASOLINE (Aquafina)
Cool stuff, never seen anything like it. Apparantly I don't get out much.
Old Mar 22, 2005 | 04:18 PM
Takashi1978's Avatar
Default Re: GAS instead of GASOLINE (jaedaSC)
Here in Malaysia almost all Taxi's use GAS, cheaper and more eco friendly
Old Mar 22, 2005 | 04:25 PM
white rocket's Avatar
Default Re: GAS instead of GASOLINE (Takashi1978)
My old flat deck ran on propane. Robs a bit of power from the vehicle but the savings in fuel were worth it back then
Old Mar 22, 2005 | 05:49 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: GAS instead of GASOLINE (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">something about that set-up B18CRSpec shows is still pretty scary to me </TD></TR></TABLE>
The engine would actually run better on propane.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C&D &raquo;</TD></TR><TR><TD CLASS="quote">New fuel lines were fitted, along with a new fuel rail and injectors from Bi-Phase Technologies of Lake Lillian, Minnesota. As propane actually has a higher calorific value than gasoline, its stoichiometric ratio—the ideal air-fuel mixture—is 15.7:1 versus gasoline's at 14.7:1. The smaller injectors obviate the need for any change to the car's stock powertrain controller. And with an octane value of 104, propane is ideal for high-compression engines. </TD></TR></TABLE>
http://www.caranddriver.com/ar...ber=1
Old Mar 22, 2005 | 10:46 PM
Stealthycivicsi's Avatar
No more smoking in cars.
Old Mar 22, 2005 | 11:21 PM
Sack Master's Avatar
Default Re: GAS instead of GASOLINE (Stealthycivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>More efficiently but not make as much power. I have yet to see a propane powered vehicle make close to as much power as it's gasoline powered counterpart. I'm sure with more $$ incolved in research that could change though. A bone stock triton v10 makes about 50 more hp and 20 more lb ft of torque than that interceptor. Of course that car in the link you sent was cool as hell. And propane runs cool so nitrous would be a very good option.
Old Mar 23, 2005 | 12:01 AM
.water's Avatar
ya in South Korean they use LPG gas on taxi these days..also ffew of vans,cars,trucks
Old Mar 23, 2005 | 12:09 AM
fullraceacura's Avatar
Default Re: GAS instead of GASOLINE (Chris DC2)
ok enough is enough, what about the performance possibilities of this in our cars
Old Mar 23, 2005 | 01:35 AM
Leventis's Avatar
Default Re: GAS instead of GASOLINE (itr#xxxxlives)
I´m running my EG9 on LPG because here in Germany gasoline is very expensive. here some pics:
LPG contains here 60% Propan/Butan and 40% alcohol. The temperature in the bottle is -47°C so it stays liquid. LPG has about 103-110 octane, it depends on the mixture of the gases and alcohol.
With the old tarantini system, it had a loss of 10-20% in performance and 10-20% more gas usage in comparison with gasoline.
I have on my EG9 a sequential system, that means that I have a second ECU and 4 LPG-injectors for each cylinder on the intake manifold, normally it should have nearly the same performance as with gasoline, and the LPG usage shoud be also nearly the same. My car runs a bit weaker with LPG, but I don´d care so much , because if I want to race I can switch any time to gasoline. The only disantvantage is the extra weight in the trunk. There is a new system called icom, where no LPG injectors are needed, the gas is injected through the stock injectors, with this method an increased performance of 10% should be possible due to the higher octane and low temperature of LPG, but I don´t know exactly if that is true
Old Mar 23, 2005 | 01:46 AM
.water's Avatar
Default Re: GAS instead of GASOLINE (Leventis)
^ very interesting
Old Mar 23, 2005 | 04:17 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leventis &raquo;</TD></TR><TR><TD CLASS="quote">I´m running my EG9 on LPG because here in Germany gasoline is very expensive.
I have on my EG9 a sequential system, that means that I have a second ECU and 4 LPG-injectors for each cylinder on the intake manifold, normally it should have nearly the same performance as with gasoline, and the LPG usage shoud be also nearly the same. My car runs a bit weaker with LPG, but I don´d care so much , because if I want to race I can switch any time to gasoline. The only disantvantage is the extra weight in the trunk. There is a new system called icom, where no LPG injectors are needed, the gas is injected through the stock injectors, with this method an increased performance of 10% should be possible due to the higher octane and low temperature of LPG, but I don´t know exactly if that is true</TD></TR></TABLE>
It would be interesting to see the result of increasing your compression ratio to take advantage of the higher octane rating. Does 13.5:1 sound too high?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">More efficiently but not make as much power. I have yet to see a propane powered vehicle make close to as much power as it's gasoline powered counterpart. I'm sure with more $$ incolved in research that could change though. A bone stock triton v10 makes about 50 more hp and 20 more lb ft of torque than that interceptor. Of course that car in the link you sent was cool as hell. And propane runs cool so nitrous would be a very good option.</TD></TR></TABLE>
Grilling and whip-its: together at last!
Hey with a propane powered vehicle, it would be possible to have a grill attachment. Mmm... barbecue.
Old Mar 23, 2005 | 04:28 AM
TyPe-R6's Avatar
Weird
Old Mar 23, 2005 | 07:23 PM
Default Re: GAS instead of GASOLINE (TyPe-R6)
Hey with a propane powered vehicle, it would be possible to have a grill attachment. Mmm... barbecue.</TD></TR></TABLE>I like your reasoning
sik_sol
Oct 30, 2006 09:26 AM
HondaHemi
Dec 3, 2005 05:51 PM
B18CXr
29
Aug 13, 2005 05:48 PM
HatchBox
Jul 3, 2004 07:58 PM
madchiller
Aug 30, 2001 12:47 PM
