Fuel rail insulators
Old Feb 22, 2004 | 05:29 PM
zCivic's Avatar
Default Fuel rail insulators
I'm installing a skunk2 intake manifold using DSM 390 injecotrs. If I remove the fuel rail insulators, I can get the injectors seated correctly, but if I use any of the insulator even cut in half, the injectors are too short. Are there any other options, can I install without these insulators?? Or can I just get some rubber and install between the manifold and the fuel rail???
Old Feb 22, 2004 | 05:58 PM
RedlinedVTEC's Avatar
Default Re: Fuel rail insulators (zCivic)
Are you refering to those plastic spacers that sit between the fuel rail and the intake manifold? If so you don't have to use them. When I was running an ITR manifold I didn't. Save them though if you ever change manifolds you may need them.
Old Feb 22, 2004 | 06:02 PM
zCivic's Avatar
Default Re: Fuel rail insulators (RedlinedVTEC)
yep thats what I'm referring to. So just let the fuel rail sit directly on the mani and it wont cause any problems??
Old Feb 22, 2004 | 06:23 PM
Nope you'll be fine.
jon570
Mar 7, 2019 07:01 AM
maximusmda
Jan 24, 2010 12:05 PM
euclid
Jul 20, 2003 10:39 AM
dabomb
Apr 17, 2003 02:22 PM
jabroni95gsr
Apr 15, 2003 05:05 AM
