fuel pump problem?
Old Jun 19, 2007 | 02:53 PM
huge230's Avatar
Default fuel pump problem?
I was checking my fuel system for leaks after replacing some things including my fuel pump with a new Walbro 255, anyway the pump primed and i had some leaks so i would tighten something or whatnot and try it again.
After doing this maybe 8 times over the course of an hour, the fuel pump will not prime anymore.
I have tried another pump outside the tank (shouldnt matter it was outside the tank?)
Tried new ECU
Main relay clicks
No blown fuses I dont think.
Where do I look next?
I know the main relay can click and still be bad but is there anything else I am forgetting to check?
Old Jun 19, 2007 | 02:56 PM
92_civic's Avatar
Default Re: fuel pump problem? (huge230)
is the fuel pump still good...no offense, but if you've been in an outta there 8 times...chances are
check the pump out side of the tank
Old Jun 19, 2007 | 02:58 PM
huge230's Avatar
Default Re: fuel pump problem? (92_civic)
i tried the original pump (not while back in the tank but just inside the car) and it didnt work either so I dont think its the pump
cgodfrey19
Feb 5, 2012 06:32 PM
B16afmaxt
Mar 22, 2010 06:26 AM
arospeedintegra
Mar 6, 2007 02:26 PM
GDM S2K
Honda S2000
Jan 8, 2007 01:30 PM
dyases
Apr 30, 2004 06:45 PM
