Fuel Problem...or maybe not...
Old May 7, 2002 | 11:09 PM
civicboisi's Avatar
Default Fuel Problem...or maybe not...
Gotta question for you guys...i have a 90 dx hatch with a 89 crx si motor. I'm using everything stock including ecu, fuel rail and reg, injectors, manifold, and header. Now my car won't go past 4800 rpm while im driving on first gear. Second goes but its slow as all hell but slowly passes to roughly 5000 rpms and stops. Third to little bit more and so on. At neutral rev, it would go up rpms faster but stutter around 6000 rpm. A buddy of mine says its the fuel pressure. Is that right? PLEASE HELP. Thanks for any help
Old May 8, 2002 | 05:44 AM
gsr squirrel's Avatar
New User
Default Re: Fuel Problem...or maybe not... (civicboisi)
sounds like your not getting any fuel up top, how long have you had this swap before it started being a problem?
Old May 8, 2002 | 06:48 AM
BoM's Avatar
BoM
Default Re: Fuel Problem...or maybe not... (gsr squirrel)
new fuel pump
or one from a dohc engine
Old May 8, 2002 | 10:11 AM
civicboisi's Avatar
Default Re: Fuel Problem...or maybe not... (BoM)
i think i do have a problem with fuel on the high end...but i dunno if that would screw everything else up...it doesnt pick up as fast as a Si is supposed to. This problem started right after i put the motor in. Bout a month now and im not driving it till i figure out whats wrong. Please help.
Old May 8, 2002 | 12:21 PM
civicboisi's Avatar
ttt please help guys!!! thanks
Old May 8, 2002 | 03:10 PM
civicboisi's Avatar
any help would do....please!!! thanks
Old May 9, 2002 | 05:51 AM
88_SC_CRX_Si's Avatar
New User
Have you had a chance to check you cam pully alignment... Pull your plugs, and check for signs of running lean. Someone might have switched out the head, with a D15 throwing the cam timming off, even tho you have it set right visually.
Just some thoughts....
[Modified by 88_SC_CRX_Si, 6:58 AM 5/9/2002]
daniel-crx
Mar 2, 2009 11:43 AM
95GSRDC2
Jul 13, 2007 04:19 AM
layinlowon14s
Mar 27, 2007 12:29 PM
Maxime
Jul 10, 2005 05:46 AM
