Fuel Problem
Old Oct 7, 2008 | 01:34 PM
H2Bcoupe's Avatar
Default Fuel Problem
Just finished my swap in my 99 ex, 1st crank turned it on perfectly, let it sit for a day then when i went to start it again it was smoking and smelling strong like gas, and when i checked the problem was the injectors are staying open dumping to much gas, i changed ecu's to see if that was the problem but it wasnt, i checked and somehow a negitive got power, that is most likely the cause huh?
Old Oct 7, 2008 | 02:50 PM
Ryan#1's Avatar
Was the ground that you checked actually grounded when you checked it? You know that the ground wire will test power until you complete the circuit and actually make it a ground. Otherwise it's very poorly grounded and that will give a power reading too.
Old Oct 7, 2008 | 03:08 PM
H2Bcoupe's Avatar
yea it was connected, i put a different ecu but the same as mine (p30) i found out that the ground bhind the dizzy has power, so im guessing theres a shortage somewhere? we followed the negitive that has power to the plug thats infront of the steering wheel in the engine bay that leads to the inside fuse box
Akodo
Audio / Security / Video
Jan 12, 2016 10:08 AM
Efjdm88
Jun 20, 2012 01:15 AM
01typerboi
Mar 29, 2011 04:02 AM
H2Bcoupe
Oct 7, 2008 03:14 PM
RaCk
26
Aug 9, 2006 12:50 PM
