Fuel pressure regulator
Old Dec 7, 2011 | 02:51 AM
uvamosk's Avatar
Default Fuel pressure regulator
So while working on this bogging issue I found I had fuel pressure set to 42psi at idle no vac on fpr.
Should I bump this to 47-50 psi..
The engine is a B20z.
Also when I put vac on it stays at the same pressure as if I had the vac off?
I read in the FSM it should drop once vac is applied..
This mean I have an fpr issue?
Old Dec 7, 2011 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: Fuel pressure regulator
Sounds like either you have no vacuum or FPR is not working. 94
Old Dec 7, 2011 | 05:51 PM
uvamosk's Avatar
Well I read 44PSI on B20Z is good pressure to run when using LS maps..
I found out today that's 44PSI on vac...
So I turned it up to 51PSI OFF VAC and when I hook it to VAC I get 44PSI...
So lesson learned, and also when you say what fuel pressure your running people say if its OFF or ON vac... ^_^
Old Dec 7, 2011 | 09:18 PM
10psiLsEf2's Avatar
Mitchell on demand says 37-40 with vaccum
40-42 with out vaccum.
Best of luck. If it smells rich out the tail pipe and is idleing rough it could have a torn diaphram causing gas to dump into intake manifold.
Old Dec 8, 2011 | 02:26 PM
uvamosk's Avatar
Well, it's all fixed now. I set it to 51psI no vac and that makes it 44psi at vac.
I'm thinking of bumping it a few more psi to help the b20z get more fuel till I dyno tune it.
The b20z needs more fuel than b18b ecu maps can give it.
rdssk8rcs1
Oct 2, 2010 07:41 AM
JdM_Eg6_SiiR
Jun 13, 2009 02:35 AM
scatuli
Mar 22, 2004 07:32 PM
BoroDB8
Mar 10, 2002 12:54 PM
BeeT
Jun 18, 2001 10:00 AM
