Fuel Pressure Problem
Old Nov 27, 2002 | 05:28 AM
rbf351's Avatar
Default Fuel Pressure Problem
i went turbo the other day. i have a huge problem now
my o rings that seal the injectors to the rail have blown apart. and i leaked gas all over the place. well i fixed that
Now i have fuel pressure at 50 and i can't lower it
we have put all the fuel parts back to stock and the pressure is still at 50
i tried and adjustable FPR and it won't go down either.
is it possible that i blew up my injectors?
Old Nov 27, 2002 | 05:49 AM
b19coupe's Avatar
Default Re: Fuel Pressure Problem (rbf351)
Even if there is something wrong with your injectors, you should be able to control your fuel pressure.The fuel pressure regulator controls fuel pressure by bleeding pressure back to the fuel tank through the fuel return line. Your guage may be faulty, or you have a problem with a restriction in your fuel return circuit.
Old Nov 27, 2002 | 05:59 AM
metal-x's Avatar
Default Re: Fuel Pressure Problem (b19coupe)
50 at idle?
Old Nov 27, 2002 | 06:04 AM
Desslok's Avatar
Default Re: Fuel Pressure Problem (metal-x)
Is that w/ the vacuum unplugged from FPR and plugged?
Old Nov 27, 2002 | 06:10 AM
rbf351's Avatar
Default Re: Fuel Pressure Problem (sp)
we checked and replaced the lines from the tank to the rail. so those are clean
we put a new gauge on and a new FPR. we even tried an adjustable one
also wheter the vaccum is pulled in or out it stays at 50, which is why we thought it was a fautly gauge
Old Nov 27, 2002 | 06:12 AM
b19coupe's Avatar
You got me stumped.
Old Nov 27, 2002 | 06:46 AM
337 GTI 1.8t's Avatar
Did you damage the diaphagm in the fpr from excessively high fuel pressure under boost? Were you running an FMU?...hmm now i see you replaced all the parts back to stock...maybe the gauge is busted OR the injectors were exposed to such high fuel pressure from the FMU that something happened to the pintles in the injectors...need to swap inj's to know fo sho...change the gauge also...
[Modified by GTI 1.8t, 3:49 PM 11/27/2002]
Old Nov 27, 2002 | 07:00 AM
rbf351's Avatar
Default Re: Fuel Pressure Problem (GTI 1.8t)
gauge was changed too
the only 2 parts left that haven't been changed is the dampner and the injectors
Old Nov 27, 2002 | 07:18 AM
Desslok's Avatar
If I had to guess, I would guess the injectors got damaged when the seals blew. Sounds like the FPR stuck or something, the pressure probably surged to the full output of the pump(~90?)
Old Nov 27, 2002 | 07:28 AM
rbf351's Avatar
it's not the FPR cause it's a new one, we tried 2 different ones
teknics1
May 29, 2006 12:30 PM
zseeanz
Apr 5, 2004 07:48 AM
JM Performance
Dec 20, 2001 03:51 PM
chefcris420
Jul 20, 2001 11:34 AM
