Fuel Pressure and Duty Cycle Question?
Old Aug 14, 2002 | 01:09 AM
mafay2's Avatar
New User
Default Fuel Pressure and Duty Cycle Question?
Will running higher fuel pressure help reduce the duty cycle of the injectors?
I am currently max out the 290cc injector, it is running 100% duty cycle at 38psi fp now. I just wonder if running higher fuel pressure will help reduce the duty cycle or not?
Old Aug 14, 2002 | 01:12 AM
kinesistech's Avatar
Default Re: Fuel Pressure and Duty Cycle Question? (mafay2)
It can help a little. If the injectors are maxed out upgrade them. Too much pressure will decrease flow. The amount of fuel supplied will go down with too much.
Its supposed to be set with the vaccum line disconnected and plugged. The factory spec is 40-47psi.
Old Aug 14, 2002 | 01:18 AM
mafay2's Avatar
New User
Default Re: Fuel Pressure and Duty Cycle Question? (kinesistech)
so let say if I turn it up to around 45psi, will it help? It still within factory spec, so it shouldn't be too bad for the injectors.
Old Aug 14, 2002 | 02:00 AM
B18C-EJ1
Guest
Posts: n/a
Yes, and you can also go about 10% over stock FPR settings without any ill effects.
the.hamburglar
Mar 27, 2015 07:58 AM
7rrivera7
Aug 21, 2003 10:07 AM
RTW DC2R
Jul 4, 2003 10:14 AM
