fuel issues
Old Jan 31, 2016 | 09:23 AM
gerresj's Avatar
Default fuel issues
I recently installed a walbro 190 into my 97 civic coupe...motor is a b20b...when I let off throttle while driving I get a heavy gas smell....no smell when idling or under acceleration...help point me in the right direction
Old Jan 31, 2016 | 10:16 AM
v4lu3s's Avatar
RTFM
Default Re: fuel issues
Double check your install. If the only thing that changed was the pump inside the tank you messed something up and fuel or fuel vapor is escaping.
Old Jan 31, 2016 | 10:18 AM
gerresj's Avatar
But wouldn't it be a constant odor if something were wrong with the install?? Im only smelling the gas when I let off the throttle
Old Feb 1, 2016 | 04:41 AM
v4lu3s's Avatar
RTFM
No smell before install right? Smell after install right? The only thing that changed was what you did...
Old Feb 1, 2016 | 06:25 AM
gerresj's Avatar
Checked everything I did....no leaks nothing loose...could it be running rich and if there were an exhaust leak I could be smelling it from there
Old Feb 1, 2016 | 11:35 AM
motoxxxman's Avatar
check the fuel rail and fuel pressure regulator for any leaks. also take a peek at the return line off the FPR
Old Feb 1, 2016 | 12:37 PM
v4lu3s's Avatar
RTFM
I would also be checking the gasket on the pump holder assembly to make sure an edge is not pinched or folded over.
dk4ever
May 7, 2007 08:35 AM
Tchleung
Dec 12, 2004 11:54 AM
ProjectLudeSiR
Jul 21, 2003 10:48 PM
