fuel filter
Old Jan 5, 2003 | 02:17 PM
get wet racing's Avatar
Default fuel filter
Can someone tell me where the filter is, Is it hard to change. thanks?
Old Jan 6, 2003 | 01:03 AM
95hatchy's Avatar
New User
Default Re: fuel filter (get wet racing)
the filter is not hard to change, and it is located on the passanger firewall. just follow the fuel line from the fuel rail. good luck
Old Jan 6, 2003 | 06:03 AM
b19coupe's Avatar
Invest in a 14mm line wrench (flare nut wrench) so you don't round off the fuel line nut.
Old Jan 6, 2003 | 06:16 AM
88_SC_CRX_Si's Avatar
New User
It may take more then one wrench, of the above mentioned. Sometimes you have to hold the "other" banjo bolt, to keep the assembly from twisting on you. It's rubber mounted, so it can be a PITA sometimes. Also pick-up some new "crush washers" this will help in avoiding leaks when re-assembled... hehehe
.Hatches.
Mar 17, 2008 05:53 PM
moonpieboy
Oct 9, 2005 09:57 AM
94DOHCDELSOL
Feb 4, 2005 11:00 AM
Ti3d in
Jul 27, 2004 07:57 PM
AK94GSR
Aug 7, 2002 08:02 PM
